Bronco Type XIII 1/35
  • Minorcan
    • Jul 2019
    • 9
    I came across a Bronco Type XXIII 1/35 kit. I’m thinking of what diameter WTC to use. The beam is 3.4”. Has anyone put a 3.0” WTC in one?
    • 13976
    2.5"...………………...
    • Minorcan
      • Jul 2019
      • 9
      Thanks, I was hoping I could use a 3.0”. If the beam is 3.4” what am I missing?
        • 13976
        You're missing enough annular space in which to place foam.
        • Minorcan
          • Jul 2019
          • 9
          Ahh, well said. I take it the WTC is a 2.5”? It’s hard to estimate without a WTC and kit in hand. Thanks Much.
            • 13976
            Yes, that's a 2.5" SD. A 3" SD would be too big of a diameter.
            • Minorcan
              • Jul 2019
              • 9
              Thanks for posting the pics, your experience is invaluable. Your posts, advise and willingness to share has helped me and many other folks immensely. I have one of your old D&E Miniatures 3.5” WTCs. It has the adjustable ballast space and the conical wedge rotary valves. Still water tight and works perfectly. It’s a testament to you engineering and modeling skills. Thanks again.
                • 13976
                Damn, Minorcan;134295! You gotta eventually come up for air, right?
                On a serious note: Much appreciate the appreciation. Just passing on what others taught me. Glad to help. The end-game is to leave the field better than you found it.
                The Horrible
                • george
                  • Dec 2010
                  • 731
                  Thank You also for sharing your Wisdom with us. David the Wise One!
                    • 13976
                    You too, Brutus?!………...
                      Some more ammo for your building arsenal: https://www.youtube.com/watch?v=vLp4VloLND0
                        • 3752
                        I'll throw in my WIP, https://forum.rc-sub.com/forum/build...nco-type-xxiii
                        Bottom line is, we are here to help you if you should need it.
