Daily submarine picture
This is a sticky topic.
    Luckey Dragon lantern. Good luck christing. Ive been trying for years to explain the oilcanning illusion in fotos of boats to no avail, but obviously that one hasent even been in the water to have any pressure. The actual fact is there are no compound bends in the steel plates when attaching them to parabolic framework of the hull. Depending on the POV and the angle of the light source seams will show up as sharp contrast points giving the uneducated eye the apperance of concaveing surface. Im not saying there is no oilcanning on subs ships or aircraft due to stress factors on the viehicle, just that your eyes play tricks
      Well, having spent 2 hiches in the Navy, I can tell you No they dont wear dress uniforms all the time, only summer or tropical area of operation is whites, dress blues when in winter or temperate zones. Dress uniforms are for special ocasions. There also undress, whites as well as blues for operations underway, such as manning the rails or line handling in port. These uniforms look ok from a distance, but up close is another story. Most boat crews wear the uniform of the day which is coveralls or dungerese during normal operations. Those newer Japanese boats are immaculate inside and out, not like the IJN diesels or the P&S type boats we had in WWII
      • modelnut
        • Jun 2011
        • 140
        #618
        USS SNOOK
        • modelnut
          • Jun 2011
          • 140
          #619
          USS SHARK
          • modelnut
            • Jun 2011
            • 140
            #620
            USS SNOOK
              Thank you modelnut of that picture of a Skipjack class boat. They really were the
              hotrod of the seas.
Name:	Flash drive 2 550.jpg
              • modelnut
                • Jun 2011
                • 140
                #622
                You're welcome. Can you tell Im excited to be getting HWSNBN SKIPJACK kit in a month or two? I have Moebius 72 scale kit on pre-order.
                - Leelan
                  hotrod of the seas.
                  [ATTACH=CONFIG]12663[/ATTACH]
                  THAT is a spectacular photo!
                    • 13968
                    #624
                    All other round-hull submarines simply plow through the water while at a high bell on the surface. Only the SKIPJAK'S 'knifed' through the water. What grace and beauty!
                      Yes, I love to be able to look down thru the water and see the hull of the sub below.
                        An Upholder in Canadian service.Click image for larger version
Name:	HMCS Windsor.jpg
                          Dolphin masts and sail.Click image for larger version
                          • 639mpa
                            • 68
                            #628
                            A Japanese sub made a port call at Pearl Harbor in the early 70's when I was stationed aboard the Tautog SSN639. I was given a tour of the ship by the XO. It was VERY clean. I was also impressed by the watertight doors. The were round and the top of the opening was much lower than ours. Unfortunately, we could not return the favor because Foreign Nationals were not permitted on US nuclear powered ships at that time.
                              Interesting.
                                Upward view of the masts of USS ToledoClick image for larger version
Name:	USS Toledo masts.jpg
