1/96 ScaleShips Oscar II
    • 12321
    Originally posted by HardRock
    Der Kasten mit Löchern!
    [ATTACH=CONFIG]n109131[/ATTACH]
    Her Majesty enquired as to my intentions - having wandered down to the bunker and spied me building a "coffin"!!! "One more ****ty video", I said etc etc.
    LOL. Yesh. That could give a neglected spouce reason for concern. Nice looking box. (you should have assured her with, "but, darling, I put air-holes in it!"). Long ago Ellie stopped asking.
      This box thing might be getting a little out of hand. I built this new box for the Alpha yesterday.
ID:	109280Click image for larger version
      and now she's started calling me BOX MAN!
      • Peter W
        • May 2011
        • 509
        Scott
        Will that coffin do for Australian cricket ? I like the box the Alfa looks very secure in that. Going to be a bit of a lump with the Oscar in one though...
        Peter
          Oh my giddy Auny.... All out for less than 70 runs! The Australian selectors might need to came and have conversation with your son about future employment.
            It all clear to me now..... Inside every Oscar there is a 212 trying to get out! Click image for larger version
            • Peter W
              • May 2011
              • 509
              That would.be the Oscar III they are taking forever to build, the parasite sub carrier like they did with the Yankee.
              Peter
              p.s. didn't know they were using a 212!
                I took it out for a run in the pool today. I'd forgotten what a great little boat this is. It was scooting around at about three feet under the surface and I was having a wonderful time.... until I slowed down and THEN realised that it was out of gas! So a very cold (and chastening) swim later; I took it back into the bunker and sat it in the hull of the Oscar to dry off and was struck by the size comparison. They are both the same scale (1/96). Quite striking.
                  • 12321
                  It all clear to me now..... Inside every Oscar there is a 212 trying to get out! [ATTACH=CONFIG]n109427[/ATTACH]
                  That's just .... SICK!
                    Could have been worse.... Imagine if there was Skipjack in there!
                      This is the rear of the forplane and torpedo mount. The control arm for the forplanes was on top of the mechanism and made a simple control rod connection impossible. So I made a do-dad to bring the control point down next to the retract mechanism linkage. Works OK too.
ID:	109460Click image for larger version
ID:	109461Click image for larger version
ID:	110406Almost there! Final fitting of the SD and snort valve.
ID:	110407The front bulkhead with the retract and forplane servos and the hydraulic pump.
ID:	110408Front end wiring.
                        • Davidh
                          • Nov 2010
                          • 719
                          Scott brought the Oscar to the subregatta this morning. Let me just say that there were some who needed to scrape their jaws off the ground. This boat is a show stopper. Simply stunning work . We need to get Brads V's typhoon to Scott's workshop so it can get a real weather job.
                          David H
                            Great! Pictures please
                            • Davidh
                              • Nov 2010
                              • 719
                              O.K Here we go.
ID:	110493 Click image for larger version
ID:	110494 Click image for larger version
ID:	110495 Click image for larger version
                              David h
                                Thanks Dave. Fun day, many faults detected, back to the bunker!
