The first cut on the stabilisors, decided to leave some more meat, otherwise i will end with flimsy stabilisors.
Second cut, followed the outlining of the new rudders, it's starting to become something.
Drilled the new location of the shafts and placed the new rudders, used some clamps to keep them at position.
After making the new steeringcontrols and placing the reiinforcement bars i discovered the throw of the rudder was limited by the bars.
By making a 45 degrees bevel on top of the rudders i've got me some more room to move them.
The finished rearpart, it does like the real one, not exactly the same but close enough.
Found out that the front navigationlight was different, made this item and had to grind away some of the lower structure, by doing this, the light is visible from the front of the netcutter.
Took everything off from the model which i don't want to paint, time to use some primer.
Today i've got me a break in the weather, which means time to use some primer, all items are done, due to the weather it can dry, after that i can store the items 24 hrs for hardening.
