Hi Sam and Tom,
On the rear white light could you make the lens from clear silicone? Sort
of like those LED candles have a silicone flame shape. LED candles might
be a cheap source for led, battery, switch, and resistor.
I appreciate the motivation in building wisdom you laid on us.
"As an encouragement to those first timers building, or those that have gone stagnant, or those that want to build (which I highly recommend - especially if you buy a pre-made wtc like this Sub-Driver), do at least a small amount of work on your sub every week if you can. Before you know it, you will have a completed sub. I am trying to share this with Sam. If he gets into the habit of doing even a small amount of work done, he will eventually finish his sub. If he does not, it then becomes easier and easier to leave it on a shelf or in the garage to be forgotten or uncompleted."
Scott T
Scott T
