Skipjack
  • SSN SonarTech
    • Jul 2012
    • 116
    It there a preferred size to photos posted?
    US Submarine Force: Making the Navy worthwhile since 1900
    • SSN SonarTech
      • Jul 2012
      • 116
      Ok how do you post photo. Says I am not allowed to create attachments
        • 13941
        I simply post my stuff to an outside photo hosting service. Write the photo URL into your text and the big photo will show up.
        • SSN SonarTech
          • Jul 2012
          • 116
          Thanks David, which is a good one to use as I have never done this.
          Steve
            • 13941
            Steve
            This is my account: http://www.servimg.com/images.php?cat_id=0&start=0
            Look it over, a bunch of photos I've posted to that hosting site.
            Set up your own account at this host, then copy pictures from your hard-drive to this site and then all you need do to post them to a forum post is paste the photo URL into the text of your post.
            Confusing at first, but it will let you post big format pictures to your posts here and other forums.
            Some examples of hosted pictures presented here:
              Nothing wrong with a Ping Jockey, son. I almost was one. Did BE&E at FSS Key West. Had to pretend to be a sonar striker fo phase one. NSWs at the AUWS, had to audit the class in those days. You active?
              • SSN SonarTech
                • Jul 2012
                • 116
                No retired in 2000-25 years. STSCS/SS/NAC was P-3 AW for 10 years before I saw the light.
                • SSN SonarTech
                  • Jul 2012
                  • 116
                  while trying to adjust the stern planes, ole ham fist here stripped the set screw. How can I fix this? Could not seem to get it tight on the shaft.
                    • 13941
                    What stripped, the resin thread at the stern plane itself (likely), or the thread at the metal yoke (less likely). In either case, remove the set screw, swizzle some thin-formula CA in the bore of the threaded hole and hit it with some acellerator (applied with a stick or piece of 1/16" rod). Retap (it's a 4-40 thread) and you're good to go.
                    • SSN SonarTech
                      • Jul 2012
                      • 116
                      Thanks stripped resin, still trying to get sevrimg account and then the pictures will start.
                      • SSN SonarTech
                        • Jul 2012
                        • 116
                        test of picture Static Gato ..Last project; Start of skipjack
                          GOOD! Another builders thread! Welcome aboard SSN Sonar Tech.
                            ALRIGHT! WHOS the smiley face in the center of the picture?!!! Anybody we know?
                              MERRIMAN! Iron that shirt; get a hircut; and STOP thinking about sex!
                                • 3668
                                #30
                                Laugh it up fuzzball.
