Skipjack
    #106
    Originally posted by SSN SonarTech
    it there a guide to setting up a WFLY WFT08X and a leptron RX . The instructions for the transmitter (that came with it) talk about 2.4 GHZ operation and I have 72 Mhz. I followed M's wiring diagram to hook everything up. I thought I had come across a TX setup guide but can not seem to find it.
    That 2.4gHz transmitter is entirely unsuitable for operation with the 75mHz Lepton-8 receiver. Two different bands, and two different forms of modulation. You need to find a replacement 75mHz RF module for the transmitter (with antenna!), or find yourself another transmitter on the 75mHz band.
    • SSN SonarTech
      • Jul 2012
      • 116
      #107
      My transmitter and my lepto 6 are 72 Mhz. the instructions that came with the TX are for the 2.4 ghz model. I guess I was not clear enough. I am looking for a set up guide. The most channels I have used in the past are 2 channel systems and I want to make sure I have everything hooked up right and what controls what on the transmitter. Thanks for you help
        #108
        Oh,
        Set the transmitter for mode-2 and for 'airplane', not 'helicopter. Then just worry about servo reversing and end-points.
        • SSN SonarTech
          • Jul 2012
          • 116
          #109
          01-24-2012, 08:40 AM
          Originally posted by vital.spark View Post
          Hello Kevin,
          Daved mentioned your guide is a god-send, where can I find it? At the moment I'm going one step forward and 2 steps backward.
          Regards,
          Myron
          Scroll down the forum until you find LINKS TO TECHNICAL DOCUMENTS which will take you to KNOWLEDGEBASE
          scroll down to find Setting Up The WFLY Radio WFT08 8 ch
          Is this guide still available? The web page says it is unavailable? Seem to be just what I am looking for
            • 3769
            #110
            Try this:
            • SSN SonarTech
              • Jul 2012
              • 116
              #111
              Thanks for the info. what I was looking for.
              • SSN SonarTech
                • Jul 2012
                • 116
                #112
                Everything hooked up, No smoke!!! everything works as advertised but I can not seem control the throttle. I set the endpoint to 50 as I have read about. Not very smooth response and no reverse. Is there something I am missing? Also need to make new control rods off the servos after bending they are to short. Moving on slowly Merry Christmas to all
                  #113
                  Did you attempt to re-program the ESC? Go to the MTronik's site for info on that.
                  • SSN SonarTech
                    • Jul 2012
                    • 116
                    #114
                    Thanks I will try that. And thanks David for all you r help Have a Merry Christmas and great New Year even though we are going to be having 70 degree weather
                      #115
                      Drag that arking-sparking-spewing, steaming pile of ***** over here and I'll fix you up.
                      • SSN SonarTech
                        • Jul 2012
                        • 116
                        #116
                        Hey now its Fast Attack tough.. Thanks for the offer but I will have to delay as I am going out of town for a few days. I had a duh moment and did not think of calibration even though I have use this brand of esc before. Once again you were right on the mark as your advice worked like a champ.
                          #117
                          OF COURSE I WAS RIGHT!!!!!
                          What's wrong with you people?!!....
                          Safe trip, pal.
                          • Pawly
                            • Jun 2013
                            • 59
                            #118
                            Not sure if I am in the right area, I am sure you will let me know if I am not.
                            I was wondering when is sub driver open for business this year?
                            Mrs. Santa got me a SkipJack model, and I have bought the fittings kit, sub driver and PE kit to get it going. I just ordered them on the 4th Jan. Was checking to see when they are open.
                              #119
                              You're fine. As far as I know it is. What are you looking for? We're all coming in back from vacation and getting back to work for another year
                              • Pawly
                                • Jun 2013
                                • 59
                                #120
                                I have found what I am looking for on this site and its links, thank you. I have purchased the sub driver and fittings kit for SkipJack, I will be building USS Scorpion. I also have a type IX that I would like to convert. I will see how the Skipjack goes. I have been building what you guys call targets in 1/72 scale. The biggest, which I will start latter on this year is USS Constellation CV64. She will be in 1/72 scale as well.
