Trumpeter 1/144 Gato build
Please forgive me for the temporary hijacking of this thread.
I bult a 1.5 dia sub driver based 99.99% on, He Who Shall Not Be Named's design, (we hope he does not mind).
The Sub Driver is not complete yet, but it should be soon, (lets hope it works I don't want to do that again).
Close up of the forward control surface. I have not figured out the next step.
👍 1Comment
👍 1
I used the motor assy from the Nichimo model I19. I wanted to use a single motor to drive two screws.👍 1Comment
The start of the conning tower. the Sea Tiger had stairs.
Only one set of rails, too lazy to make a second set.
👍 1Comment
The 1.5 dia sub driver in place.
I have not cut the flood holes yet.
I have the lead weight shaped to the hull and the foam shaped to the sides of the sub.
Showing the placement of the fill valve of the ballast tank.
I decided to use gas, but I did make SAS system (Don't tell H.W.S.N.B.N.).Last edited by small sub guy; 05-03-2018, 06:09 PM.Comment
But, damn! get bigger pictures up there! Are you using a photo hosting site for these? If so, change the file size to fill the screen when you post. Please!
DavidWho is John Galt?Comment
I forgot to post the latest updates
Sea Tiger (way too clean)
opened the rear tubes to eliminate trapped air
Cutting flood holes
Flotation foam in the bow (if you look closely you can see the 1/2oz weight in the starboard inner wall)
Stern flotation foam (the linkage is yet to be connected)
The underside of the deck floatationLast edited by small sub guy; 12-14-2018, 10:42 PM.Comment
