Trumpeter 1/144 Gato build
    • 12314
    Originally posted by small sub guy
    Forgot this one
    Good looking stuff. Can you make these pictures larger for these old, tired eyes?
    • small sub guy
      • Dec 2009
      • 45
      Please forgive me for the temporary hijacking of this thread.
      I bult a 1.5 dia sub driver based 99.99% on, He Who Shall Not Be Named's design, (we hope he does not mind).
      The Sub Driver is not complete yet, but it should be soon, (lets hope it works I don't want to do that again).
      Close up of the forward control surface. I have not figured out the next step.
      • small sub guy
        • Dec 2009
        • 45
        This is a view from the inside unsure if I should make the control surfaces move or fold.
        • small sub guy
          • Dec 2009
          • 45
          I used the motor assy from the Nichimo model I19. I wanted to use a single motor to drive two screws.
          • small sub guy
            • Dec 2009
            • 45
            The start of the conning tower. the Sea Tiger had stairs.
            Only one set of rails, too lazy to make a second set.
            • small sub guy
              • Dec 2009
              • 45
              The 1.5 dia sub driver in place.
              I have not cut the flood holes yet.
              I have the lead weight shaped to the hull and the foam shaped to the sides of the sub.
              • small sub guy
                • Dec 2009
                • 45
                Click image for larger version  Name:	IMG_0284.JPG Views:	1 Size:	7.6 KB ID:	126159
                Showing the placement of the fill valve of the ballast tank.
                I decided to use gas, but I did make SAS system (Don't tell H.W.S.N.B.N.).
                • small sub guy
                  • Dec 2009
                  • 45
                  We now return you to your regularly scheduled thread.
                    • 12314
                    Nice work, sir! Will Seaman Hornsby be featured as guest at the party on deck? Good sound engineering on display here.
                    But, damn! get bigger pictures up there! Are you using a photo hosting site for these? If so, change the file size to fill the screen when you post. Please!
                    • Aquaman
                      • May 2018
                      • 6
                      Very impressive work, and in that scale ! 14
                      • small sub guy
                        • Dec 2009
                        • 45
                        I forgot to post the latest updates
                        Sea Tiger (way too clean)
                        opened the rear tubes to eliminate trapped air
                        Cutting flood holes
                        Flotation foam in the bow (if you look closely you can see the 1/2oz weight in the starboard inner wall)
                        Stern flotation foam (the linkage is yet to be connected)
                        The underside of the deck floatation
                          • 3547
                          mark,
                          the photos do not show for me.
                          peace,
                          tom
