Revell 1/72 Skipjack class USS Shark SSN591
  • crazygary
    • Sep 2012
    • 610
    G'day, Bruce!!
    Am thoroughly enjoying your progress! Great stuff!!
    Just wanted to ask what, exactly, is the function of the "shock absorber" you made mention of!!
    (O.K.! I know it's to absorb shock, M; duh!)
    Is that the part which appears to have some sort of spring loaded plunger integrated into it??
    Also, does it function, as well, as a means of securing the SD within the hull??
    Very interesting concept!!
    Any input would be most appreciated!
    CG
      • 13476
      Yeah ... it's a shock absorber, what's it to ya!?
ID:	90677Click image for larger version
ID:	90678Click image for larger version
ID:	90679Click image for larger version
      Yes, it both indexes the SD within the fragile plastic hull; and provides the means to spread a velocity induced load over time in the event the idiot Driver runs his styrene plastic model submarine into something hard.
      Yes, it's that 'springy' thing.
      • crazygary
        • Sep 2012
        • 610
        I kinda thunk maybe it wuz sumpin' to avoid unnecessary injuries
        tuh the crew in the event that da skipper should go a little "kamikaze head butt"
        crazy if he dun run outta tor-peedoeses!!
        Thanks fer th' update, boss!!
        CG
        CG
        • HvyCGN9
          • Jan 2013
          • 187
          Since the last post I have been plugging away working on the sail
          (and some foam parts (Armoured conning tower, fwd tower/funnel and aft funnel) for my club mates BB63 I flowcoated em' on the 23rd...didn't put enough catalyst in! Still tacky on 30th! I wiped off the unset goo and tried again all fixed!!.....insert sigh of relief!!)
          Anyhoo... the sail is assembled and painted, except for the top which is still to be painted as I could not decide how many mast to have up! I will have the two periscopes on some sort of float.....drilled out the two holes and inserted some evergreen tube. Using some aluminum 1/8 tube for the scopes the kit part was chopped down then got my house mate to heat the ally tube with his lighter and pushed the top part of the scope into the heated tube. Have fillered the stuff that wont be fitted.
          here are some pix....
ID:	90944Click image for larger version
ID:	90940 Click image for larger version
ID:	90942 Click image for larger version
          • HvyCGN9
            • Jan 2013
            • 187
            PS : was looking at the SD and noticed this hole in ballast tank next to the main ballast flood holes....?? Is it supposed to be there??
            Cheers Bruce
              • 13476
              Access for the Allen wrench should you wish to retro-fit a gas type ballast sub-system.
                • 3664
                Yes. That is a hole for your tool to get to a set screw I believe.
                (David beat me to the punch)
                • crazygary
                  • Sep 2012
                  • 610
                  Looking good, Mate!!
                  Great stuff here!
                  BTW: Any pix of your "nukie" cruiser anywhere?? Would like to see her!
                  Have a good one!
                  CG
                  • HvyCGN9
                    • Jan 2013
                    • 187
                    Thx mate!! It had me baffled as to its purpose!!
                    Cheers Bruce
                    • HvyCGN9
                      • Jan 2013
                      • 187
                      Great stuff here!
                      Have a good one!
                      CG
                      Pix of my cruisers can be seen in the Targets section of the forum....scroll down forum page!! There is also a couple of videos on youtube just look up TF72 Adelaide I think..
                      Bruce
                      • HvyCGN9
                        • Jan 2013
                        • 187
                        have begun assembly of the SD.... I was wondering if there is supposed to be a renshape plug for the hole in the center of the battery end cap? If not what is recommended for the hole?
                        Cheers Bruce
                          • 3664
                          Bruce,
                          The hole is for the waterproof, booted, toggle switch, I think.
                          tom
                          • HvyCGN9
                            • Jan 2013
                            • 187
                            Bruce,
                            tom
                            No not the switch hole the smaller hole in the center next to the switch hole its about 1/4 inch dia??
                            Bruce
                              • 13476
                              Bruce
                              An artifact from the production process. Plug it.
                              • HvyCGN9
                                • Jan 2013
                                • 187
                                #30
                                Thx mate!
                                I have spent the afternoon wiring up the main power cables, installed servo's last night....just need to get some fresh double sided tape tomorrow (old stuff ain't sticky on one side....not much use!).
                                Cheers Bruce
