revell VIIc
    • 13986
    #91
    Originally posted by satlite440
    it seems fine now time will tell..i worry more about how it will vent water/air...
    It will vent air ..... ONCE!
    But, all subsequent dives attempts with a wet deck the air will not be able to escape the superstructure. Water surface tension will bridge those long, narrow slots with water and the deck won't vent through the slots when you flood the SD.
    Therefore, you are compelled to open up big (no smaller than 1/8" diameter) holes in the deck to vent the hull adequately.
    Water won't scale for you -- there's an apparent viscosity increase with reduction of model size. Hello, Doctor Reynolds!
    I have spoken! So let it be written! (insert crack-of-thunder sound here).
      How about applying a surfactant to the underside of the deck to break up the water tension, like a detergent.
      Or maybe even some petroleum jelly.
        • 13986
        #93
        The patrolium will leach into the paint as it works its way to the outside of the boat. What a god-awful mess! That don't work. Guess how I know!
        • alad61
          • Jan 2012
          • 476
          #94
          Yeah. Been there, done that... The thing is styrene is a oil derivative as is petrolium jelly. Drop a piece of spur into a cup of petrol... Pretty soon no sprue. Though not as quick or radical the jelly will do something similar as it morphs with the styrene. As David said YUCK!!
          Cheers,
          Alec.
          Reality is but a dream...
          But to dream is a reality
          • vital.spark
            • May 2010
            • 312
            #95
            I actually sanded the underside of the VII deck smooth, removing everything but the overlaps then sprayed a smooth coat of 2K. My feeling was that if there was nothing there to catch and trap bubbles, so much the better.
              • 3759
              #96
              vital.spark, did you add any additional holes to vent air? If so where did you place them?
                ok. Wonder if sticking a small bar of soap below deck will help break up the tension?
                • reddevil
                  • Jun 2009
                  • 346
                  #98
                  I reinforced mine with plastic beams below and had no structural problems with it. regarding air or water trapped under deck, there wasn't any problem at all with water when diving; you can see some tension with it when surfacing. And with air, the main problem is the bubble trapped under deck's rearmost part, where there aren't any slot. Click image for larger version
ID:	77141Click image for larger version
ID:	77142Click image for larger version
ID:	77143Click image for larger version
ID:	77144Click image for larger version
                    • 651
                    #99
                    Originally posted by reddevil
                    I reinforced mine with plastic beams below and had no structural problems with it. regarding air or water trapped under deck, there wasn't any problem at all with water when diving; you can see some tension with it when surfacing. And with air, the main problem is the bubble trapped under deck's rearmost part, where there aren't any slot. [ATTACH=CONFIG]19969[/ATTACH][ATTACH=CONFIG]19970[/ATTACH][ATTACH=CONFIG]19971[/ATTACH][ATTACH=CONFIG]19972[/ATTACH][ATTACH=CONFIG]19973[/ATTACH]
                    is that a mini engel tank in there?
                      custom job maybe, probably around 250 ml or less.
                      • reddevil
                        • Jun 2009
                        • 346
                        #101
                        No, is a 650 CC normal one. It's an optical effect cause the deck is nearer to the camera and a little bit unfocussed. The ENGEL tank is the one fitted for my AKULA II.
                        And the second set of pictures is a mistake made when trying to load the desired ones.
                        • reddevil
                          • Jun 2009
                          • 346
                          #102
                          Hi. AS I've been requested about how I've fitted the stuff inside muy VII C, here I send you some pictures about.
                            A bit blurry. Maybe you could repost it.
                            • reddevil
                              • Jun 2009
                              • 346
                              #104
                              I',m sorry, but are not able to upload this and another two in an apropriate size. Keep trying
