Stingray Build
  • RCnut
    • Apr 2012
    • 441
    #406
    Yes, sir. The long, long wait I've put you through is almost over. Very sorry for the delay. Things have been a bit 'interesting' here of late, but now more stable.
    Glad to hear Its all getting back to normal, :)
      • 13764
      #407
      I'll consider it all back to normal after I've met my obligations to you and others. Thank you.
        • 13764
        #408
        Mamas: My sincere apology for being out of touch for so long. Things piled up here and I lost what little spare time I had for non-production work. However, there is no good reason for not keeping you and the readers up to speed on why there has been such a delay. It was irresponsible for me to just drop out of sight like that, and I won't let that happen again. My rate of progress may not be high from this point, but it will be consistent.
        That said, I re-engage with the project.
        Today's work involved producing the watertight seal and associated fittings for the little WTC that housed the motor that will operate the RateMaster:
ID:	84283Click image for larger version
ID:	84284Click image for larger version
ID:	84285Click image for larger version
ID:	84286Click image for larger version
ID:	84287Click image for larger version
ID:	84288Click image for larger version
ID:	84289Click image for larger version
          • 13764
          #409
            MAN! I wish I had a Cave..............with a Lathe.............and a Cat.
              • 13764
              #411
              Stop whining and get one. The Taig is an excellent unit for our kind of work. Cat, optional!
              http://www.taigtools.com/ Tell Daisy I sent you. No... wait ... not a good idea. Strike that.
                • 13764
                #412
                  You know what? I think I will. Thats a good price. Dont know what Id do with it but..............looks like fun.
                  • RCnut
                    • Apr 2012
                    • 441
                    #414
                    That is indeed good news David, It does look very very good and I'm more than impressed with the units and your work. I look forward to getting it into my Stingray. :)
                      • 13764
                      #415
                      Very kind of you to say so, Mamas.
                      Tonight I'll get the closue done and work out getting power from the ESC to the RateMaster motor. I'm thinking of running a Y-lead from the receivers ESC port -- one leg to the ESC that turns the pump-jet, and the other leg to the RateMaster motor. Pictures tonight.
                        • 13764
                        #416
                        Tonight I'll get the closure done and work out getting power from the ESC to the RateMaster motor. I'm thinking of paralleling the ESC output -- one leg to the main propulsion motor that spins the pump-jet, and the other leg to the RateMaster motor. Pictures tonight.
                          • 13764
                          #417
                          Tonights work:
                            • 13764
                            #418
                            Tonights work:
                            • RCnut
                              • Apr 2012
                              • 441
                              #419
                              It all looks superb, Are you still sending me a blank end part just in case I want to put in a brushless motor? :)
                                • 13764
                                #420
                                Yes, for the main cylinder -- they (I'm making two systems for you, one for me) will arrive with an installed 555 motor to drive the pump-jet and you'll have two blank motor-bulkheads that will permit installation of your own drive-motor.
                                What I'm showing in the last two posts are the work on the separate RateMaster WTC. Not to be confused with the main propulsion-control WTC.
