Stingray Build
    • 13901
    #391
    Think TYPHOON. Two side-by-side cylinders.
    • Tugfan
      • Nov 2010
      • 178
      #392
      "There are always alternatives", Spock says.
      • RCnut
        • Apr 2012
        • 441
        #393
        This just in, A customer friend of mine has finished his Stingray kit and has made it a surface runner.:biggrin:
        Pictured here wiith 2 smaller ones.
          • 2587
          #394
          That looks very nice.
          • alad61
            • Jan 2012
            • 476
            #395
            Absolutely!!
            Cheers,
            Alec.
            Reality is but a dream...
            But to dream is a reality
            • RCnut
              • Apr 2012
              • 441
              #396
              And here it is in the water, This one has a conventional Prop and rudder to power it.
                • 13901
                #397
                It's been almost FIVE MONTHS when I posted that I would have the two SD's off to Mamas for his STINGRAY models, by the end of the week. Didn't happen, they're still here! I'm so behind in stuff.
                Anyway, feeling very guilty (and Mamas has been a real gentelman about it), I've spent a good portion of the weekend working out the five servo pushrods and getting them all to pass through their respective watertight seals without too much binding. Here are the gorry pictures to prove it:
ID:	76453Click image for larger version
ID:	76454Click image for larger version
ID:	76455Click image for larger version
ID:	76456Click image for larger version
ID:	76457Click image for larger version
ID:	76458Click image for larger version
ID:	76459Click image for larger version
                All that is left is to work out the little SD that houses the RateMaster motor and gear unit, make up the devices to the main SD, get things running, and THEN get this long promised item off to Mamas.
                • RCnut
                  • Apr 2012
                  • 441
                  #398
                  That Is looking Awesome!!!! Cant wait to get my hands on that! Excellent work as usual David, I would expect nothing less. :)
                    • 13901
                    #399
                    High praise indeed. If only I was more timely with my commitments. Going to install the ESC, and other devices tonight and fire this sucker up. Time permitting I'll work out the correct ratio for the RateMaster RPM.
                    • Captain Scifi
                      • Jul 2012
                      • 24
                      #400
                      That's amazing David..!!
                      It's going to look as good on the inside as the outside eh Mamas. :biggrin:
                      Building Gerry Anderson Studio Scale replicas at www.eagletransporter.com
                        • 13901
                        #401
                        Thank you sir -- started in on your Sub-driver already, now that Mamas unit has blazed the trail.
                        • RCnut
                          • Apr 2012
                          • 441
                          #402
                          Well heres a vid of the kit built By one of my friends as a surface runner.
                          Cant wait to get mine going.
                          • RCnut
                            • Apr 2012
                            • 441
                            #403
                            When I posted this vid it was all squashed up but I have now corrected the aspect ratio so here it is again in all its glorious length :wink:
                            • RCnut
                              • Apr 2012
                              • 441
                              #404
                              David, any news on the Sub Driver for the Stingray?
                                • 13901
                                #405
                                Yes, sir. The long, long wait I've put you through is almost over. Very sorry for the delay. Things have been a bit 'interesting' here of late, but now more stable.
