Stingray Build
    • 2435
    #226
    You can Du-B bearings. these are bornze backed bearings with PTFE. They can run dry but they're designed to run best in water, as it helps keep the bearing cool, no other lubrication required. Norbert Bruggen stocks them, you can also get them on fleabay.
    I can give you a link for some exquisite little motors with planetary gearboxes, available on ebay, they do about 170RPM on 3 volts. Any good?
    • RCnut
      • Apr 2012
      • 441
      #227
      Cheers Subculture, I would appreciate any help (Links etc) you can give.
      • Captain Scifi
        • Jul 2012
        • 24
        #228
        Hi Guys,
        The target speed for the rotor is about 65 - 75 rpm, interestingly, the rotor does not provide forward momentum at all and holds a steady rate of spin whatever Stingray's forward knot speed maybe, even if that is zero. I have been studying the cabin layout and should be able to produce a CAD drawing soon (walls and floor plan). This is for the static modeller really as I am not sure what would happen if left to free flood. I know David is the expert here so was hoping for a little guidance?
        The Cabin vac forms are done and successfully test fitted one lamination of 1mm PetG with a 2 mm lamination of styrene directly over to produce the outer skin. Windows will be cut in the styrene layer and a perfect fit maintained. Mamas, you are a clever guy....
        Building Gerry Anderson Studio Scale replicas at www.eagletransporter.com
        • RCnut
          • Apr 2012
          • 441
          #229
          Just a quicky, The Ratemaster as discribed is a Contra Rotating Anti Torque Eddy Dampner, OK that was a bit anoraky but It may just work as a trim function. As it stands its a side to side paddle. So, It could affect the forward direction one way or another depending on which way its spinning. Of course it may not do much at a low RPM but it will be interesting to find out. If it works lol.
            • 13477
            #230
            Bernie,
            You know I can't resist doing an interior. You may know, but that XL-5 model I built for David Hersh (Starlog staffer) nearly forty-years ago featured not only a detailed JR. cockpit, but a fully decked out 'secondary control station' atop the main craft (I believe the model is now in the Greg Jein collection). I've gotta convert those slides to digital files one of these days.
            I'll give the STINGRAY interior the same treatment I did for the 1/96 SEAVIEW. Like, below:
ID:	68466Click image for larger version
ID:	68467Click image for larger version
ID:	68468Click image for larger version
ID:	68469Click image for larger version
ID:	68470Click image for larger version
            No problem making it free flooding.
            • RCnut
              • Apr 2012
              • 441
              #231
              Bernie,
              [ATTACH=CONFIG]14720[/ATTACH][ATTACH=CONFIG]14721[/ATTACH][ATTACH=CONFIG]14722[/ATTACH][ATTACH=CONFIG]14723[/ATTACH][ATTACH=CONFIG]14724[/ATTACH][ATTACH=CONFIG]14725[/ATTACH]
              NICE!!!! This is the stuff I have seen you do in the past, cant wait to see what you do with Stingray.
                • 13477
                #232
                I've improved my figure building skills since the SEAVIEW job, example is the recent figure work in support of the 1/72 FOXTROT project.
ID:	68473Click image for larger version
ID:	68474Click image for larger version
ID:	68475Click image for larger version
ID:	68476Click image for larger version
ID:	68477Click image for larger version
                Ironic, I got a bunch of 35mm frames from David Hersh in exchange for the XL-5 model -- most of them interior shots of the STINGRAY cockpit. I would have Phones and Troy in the front seats, with Marina on the couch behind them (talk about lavish! A couch and appointments right behind a warcrafts front-office). Boy, could those Century-21 guys imagine!
                Mamas, what's the scale of this model?
                • RCnut
                  • Apr 2012
                  • 441
                  #233
                  David, Your eyes must have magnifiers in them lol. This is why I try and stick to largish stuff. Scale Would be around the 1/35 mark. Bernies been burning oil in the night and he agrees that its about right.
                    • 2435
                    #234
                    In that case a bog standard servo should be close to bang on, as they will do that sort of RPM out of the box.
                    For Du-b bearings, Norbert sells them in small quantities (can be difficult to get otherwise) http://modelluboot.de/Zubehoer/Dichtungen.html#WDR
                    Here's a link to an english PDF which tells you all about these bearings- http://www.nomo.se/pdf/DU-gb.pdf
                    Having said that, I'd have thought straightforward delrin bearings would be more than sufficient for this sort of application- low rpm and minimal load.
                    • RCnut
                      • Apr 2012
                      • 441
                      #235
                      Well to be honest the first working one I posted on you tube had brass tubing and it worked fine, just me trying to be a bit flash with the bearings and such lol. so yeh delrin, brass bushings will all work.
                        • 13477
                        #236
                        I use those magnifying goggles a lot these day.
                        1/32nd. Excellent. Twice the size of my 1/72 figures. That big I should capture the caricature features unique to the Anderson marionettes. There's a Mike Mercury in there too I think. Oh yeah ... I'm thinking SUPERCAR. How bout you, Mamas?
ID:	68493Click image for larger version
ID:	68494Click image for larger version
ID:	68495Click image for larger version
ID:	68496Click image for larger version
ID:	68497Click image for larger version
ID:	68498Click image for larger version
ID:	68499Click image for larger version
ID:	68500Click image for larger version
ID:	68501Click image for larger version
ID:	68502Click image for larger version
                        • RCnut
                          • Apr 2012
                          • 441
                          #237
                          You can sculpt too huh! And you hate ME! lol. Supercar....funny you should mention that, I had the moulds from ENA ( Product Enterprises off late) a good few years back and did a Ltd run (2 footer) Complete with an excellently sculpted Mike Mercury. Long gone I'm afraid.
                            • 13477
                            #238
                            I can almost sculpt. My Dad was the true pro at that Craft. Still learning how. Wow! Would love to have been in on that action when you were active on SUPERCAR, as that vehicle was my first love.
                            A large r/c version of that thing is on my bucket-list.
                              • 3664
                              #239
                              Here is the closest I got to sculpting- did this years ago for special parties and Halloween with my best friend. My friend actually got some work in the movies.
                              • Captain Scifi
                                • Jul 2012
                                • 24
                                #240
                                Some quick reference for the main characters, give David something to work with, big head, small body, not proportional unfortunately but full of character nonetheless....Click image for larger version
Name:	Emergency Marineville2012-02-15-21h20m36s240.jpg
ID:	68505Click image for larger version
Name:	Emergency Marineville2012-02-15-21h27m13s111.jpg
ID:	68506Click image for larger version
Name:	Rescue from the Skies00143.jpg
