Stingray Build
    • 13641
    What are you using there, plumber's putty?
      • 2506
      That's polyester filler, Dave. The Upol brand (big yellow tin behind) over here is the equivalent to Evercoat in the States.
        • 13641
        How do you resolve the shrinkage issue?
          • 2506
          Well it looks like Mamas uses a slightly different technique to me. What I do is bulk out with polurethane foam, glass over with matt and resin, then fill over that. So I use a thinner coat, which equals less shrinkage. But I find if you go over a thick coat of filler with a thinner skim after the first layer has cured, that usually deals with any shrinkage or 'sink'.
          • RCnut
            • Apr 2012
            • 441
            Hi Guys
            In this case the shrinkage is not going to be a problem as I'm building this model without a size reference so far. To Clarify, When I'm happy with the hull sections the shape and the mating of them I will take measurements and determine what scale it is then build everything around it to that scale. At the moment its just a case of getting the shape right, I'm aiming for 32 inches in total length. To be honest this is the first time I have ever started a build without a firm scale to work too and this as I said in the first post was to seperate this build from any others out there.
            • Reckless
              • Jan 2012
              • 183
              .. stay outta the cold water....
                • 13641
                (rim-shot)
                • RCnut
                  • Apr 2012
                  • 441
                  (rim-shot)
                  Dont blame you lol. And very many thanks David, Got the stuff ypu sent today, I shall take great pleasure in perusing it tonight.
                    • 13641
                    My pleasure, sir.
                    Likely not much new to you, but maybe the color demarcation lines -- that might be useful when you get to the finish color masking chore. And the old cut-away from both an Annual and a fan produced piece (Theo, maybe?). And a copy of the venerable Phil Rae plans.
                    • RCnut
                      • Apr 2012
                      • 441
                      Its all good, Who did the Masks just out of interest? I'm coming along with it at the moment, just having a spot of lunch. Ill get it to a point and take some shots and post tonight. Then as I'm off tommorrow I will make a start on the upper raised section.
                      • RCnut
                        • Apr 2012
                        • 441
                        Done a bit more today, Have to do the upper level where the cabin sits next.
                        • RCnut
                          • Apr 2012
                          • 441
                          Had a bit of time off today so I went at it, The top layer needs softening a bit but other than that I'm quite happy with how its turning out, the white bits are the torpedo "tubes" which will be placed in holes that I will cut out.
                            • 13641
                            Sorry, don't remember who gave me those paint cheat-line drawings. Wish I did. Credit where credit is due is my rule.
                            Good work, done quickly. You, sir, are a MACHINE!
                            • RCnut
                              • Apr 2012
                              • 441
                              Coming from you sir that is praise indeed!
                              The only reason I asked about those cheat line drawings is that they were also included in the RA Kit.
                                • 13641
                                #30
                                That's it! That's where they came from. What's that guy's name?
