Bronco Type XXIII by Ken
    Wonder what Bronco had in mind for that "box".
    Too bad, if it was located more midship could it be used as a ballast tank
  • Ken_NJ
    Separating the deck
    See the previous post for finishing up on making the deck cuts.
    Here are a bunch of pics showing the result of separating the deck from the hull.
    Click image for larger version  Name:	A_IMG_9351.jpg Views:	0 Size:	52.8 KB ID:	188986
    Click image for larger version  Name:	B_IMG_9350.jpg Views:	0 Size:	54.2 KB ID:	188991
    Click image for larger version  Name:	C_IMG_9349.jpg Views:	0 Size:	53.7 KB ID:	188992
    Click image for larger version  Name:	D_IMG_9352.jpg Views:	0 Size:	56.6 KB ID:	188993
    Click image for larger version  Name:	E_IMG_9353.jpg Views:	0 Size:	55.8 KB ID:	188989
    Click image for larger version  Name:	F_IMG_9354.jpg Views:	0 Size:	53.9 KB ID:	188990
    Click image for larger version  Name:	G_IMG_9355.jpg Views:	0 Size:	55.0 KB ID:	188988
    Click image for larger version  Name:	H_IMG_9356.jpg Views:	0 Size:	53.0 KB ID:	188987
    Click image for larger version  Name:	I_IMG_9357.jpg Views:	0 Size:	53.1 KB ID:	188994
    Click image for larger version  Name:	J_IMG_9358.jpg Views:	0 Size:	54.9 KB ID:	188995
  • Ken_NJ
    Bow radial cut
    For the bow radial cut I heated a strip of acrylic with the heat gun and formed it around the hull. Then anchored it in position and cut the slot with the Exacto blade.
    Aft radial cut
    This was more simple, used a straight edge and juts made the cut.
  • Ken_NJ
    I do have the tools I used on the Marlin, you remember that. I used a pointed hard tipped tool on the Marlin. I'll keep that scribing-sawing tool in mind, looks interesting and useful. I did use the razorback saw for a quick cut to be shown later, the same one Mike used on his XXIII to make the deck cut.
    Originally posted by Ken_NJ
    Cutting the deck from the hull
    I positioned the cut below the horizontal weld lines so that when the filler piece is added, it is added to the hull section, and sanding the filler piece will not impact the weld lines on the upper deck section.
    Double sided tape was applied to the hull.
    Click image for larger version Name:	A_IMG_9315.jpg Views:	0 Size:	54.7 KB ID:	188826
    The aluminum angle was applied to the double sided tape. The tape was wide enough for both legs of the angle, holding it solidly in place.
    Click image for larger version Name:	B_IMG_9325.jpg Views:	0 Size:	49.6 KB ID:	188830
    The Exacto blade is 20 thousandths wide. Good to know how wide the cut will be.
    Click image for larger version Name:	C_IMG_9319.jpg Views:	0 Size:	54.3 KB ID:	188825
    The back side of the Exacto knife was used to score against the straight edge. I kept the knife as close to being parallel to the waterline as I could.
    Click image for larger version Name:	D_IMG_9316.jpg Views:	0 Size:	55.0 KB ID:	188829
    Click image for larger version Name:	E_IMG_9317.jpg Views:	0 Size:	54.2 KB ID:	188831
    Yup, about right. Will use a 30 thousandths filler strip.
    Click image for larger version Name:	F_IMG_9321.jpg Views:	0 Size:	49.4 KB ID:	188824
    First cut. Straight and perfect.
    Click image for larger version Name:	G_IMG_9323.jpg Views:	0 Size:	56.7 KB ID:	188827
    Click image for larger version Name:	H_IMG_9324.jpg Views:	0 Size:	56.0 KB ID:	188828
    For the more difficult turn of the hull near the stern, came up with this rig. A thin bendable piece of scrap wood.
    Click image for larger version Name:	I_IMG_9343.jpg Views:	0 Size:	52.4 KB ID:	188833
    Continued the cut from the main cut to the line.
    Click image for larger version Name:	J_IMG_9341.jpg Views:	0 Size:	54.8 KB ID:	188832
    Click image for larger version Name:	K_IMG_9342.jpg Views:	0 Size:	56.4 KB ID:	188834
    Excellent job, Ken. Here's a scribing-sawing tool I made for a similar task:
  • Ken_NJ
  • Ken_NJ
    Apply solvent to the deck joint
    Before cutting the deck from the hull, the deck halves needed to be joined together. Using the Weldon 4 solvent and a brush, the solvent was applied to the deck seam and the sections were manually squeezed and aligned so that there was a minimum deviation between the sections.
    Solvent was not applied forward of the bow cut line.
    Nor was it applied behind the aft cut line.
    And the solvent was not applied below the horizontal lengthwise cut line.
    After letting the solvent set overnight, the joints were sanded with 220 and 400 grit sandpaper. This will be further sanded prior to painting.
  • Ken_NJ
    Thanks David and Manfred.
    Romel, the tape measure may work but for me it is too flexible and unruly and difficult to manage. The 2 inch wide flexible ruler is much more manageable in this instance, I used it before on other models and it works well.
    For the curved section of the hull you could use an old tape measure as a flexible guide
    Nice progress Ken, to marry both ways David and I used will be very usefull in the future, keep going
    Methodical, logical, exacting work, pal. You're taking us all back to school.
  • Ken_NJ
    Hull cut preparation
    The forward and aft sections were joined at the central radial joint with three 080 machine screws on each side. In the end, the hull sections lined up perfectly.
    Click image for larger version  Name:	A_IMG_9281.jpg Views:	0 Size:	51.5 KB ID:	188750
    Click image for larger version  Name:	B_IMG_9282.jpg Views:	0 Size:	49.8 KB ID:	188749
    Click image for larger version  Name:	C_IMG_9283.jpg Views:	0 Size:	51.0 KB ID:	188753
    Using the mark previously made at the end of the previous post, it was transferred to the outer part of the hull. I'll be using an angle piece of aluminum to make the cut line, and be using it to make the actual cut. Very fortunately, this hull is the same flatish shape most of the length of the hull, not like modern cigar shaped hulls.
    Click image for larger version  Name:	D_IMG_9213.jpg Views:	0 Size:	51.6 KB ID:	188755,
    Click image for larger version  Name:	E_IMG_9214.jpg Views:	0 Size:	52.7 KB ID:	188752
    This curved section will require using a different method to get the cut line.
    Click image for larger version  Name:	F_IMG_9215.jpg Views:	0 Size:	53.3 KB ID:	188754
    Click image for larger version  Name:	G_IMG_9216.jpg Views:	0 Size:	52.4 KB ID:	188751
    The bow section was easy with this flexible ruler.
    Click image for larger version  Name:	H_IMG_9285.jpg Views:	0 Size:	51.9 KB ID:	188756
    Out of order picture. The aft section.
    Click image for larger version  Name:	I_IMG_9287.jpg Views:	0 Size:	51.0 KB ID:	188759
    The more difficult aft section. Note that I located the cut line going through a less conspicuous section of the hull feature in the lower right. I did this where all the cuts would be.
    Click image for larger version  Name:	J_IMG_9286.jpg Views:	0 Size:	49.9 KB ID:	188758
    Thats it for laying out the hull cuts. Next up is glueing the deck area.
  • Ken_NJ
    Radial Joint
    With the forward and aft sections bolted together, the deck area is pretty floppy. I added another tab with machine screw to hold the forward section together. This is a temporary bolt.
    The aft section slides over the forward section. I used backlighting to highlight the joint where the aft section slides over the forward section if they were to be glued and marked the end of the joint.
    Acrylic strips were cut to width and edge finished (so it looked nice).
    A heat gun (Harbor Freight) was used to heat the acrylic to get it to shape.
    The soft heated strip was pressed into the hull to get the shape. It required multiple heat sessions to get it right.
    Both sections ready for trimming and install.
    I used my Laser/Engraver to cut three templates the diameter of the sub driver.
    Estimating the hull cut and placement of the sub driver template.
    I moved the hull deck cut upwards. As long as the SD is below the waterline, but lower the better. This is just estimating at this point. The lower is probably better so there is more room for foam in the upper area above the SD. Notches were made where the cut will be so that when the cut is made I don't encounter that inner wall making difficult to make the cut with the Exacto knife.
  • Ken_NJ
    I neglected to take pictures of doing the same with the aft section. Here are both sections 'bolted' together.
  • Ken_NJ
    Something that I missed will go here when I get to it.
