My Projects
    • Jan 2020
    • 1036
    #76
    Originally posted by RCSubGuy
    Thanks Bob
      • Jan 2020
      • 1036
      #77
      Anybody have u cup seals that Bob references in his " How to build watertight seals for your RC submarine" video? Need the driveshaft seals.
        • 13974
        #78
        I got those for 1/8" and 3/16" shafts. How many?
          • Jan 2020
          • 1036
          #79
          Wow, thanks David, I would like to buy 3- 1/8", and 9- 3/16", I can send you a check or PayPal, same AOL address?
            • 13974
            #80
            No! You can send me your mailing address. How bout that?!...
              • Jan 2020
              • 1036
              #81
              Designing and resin printing a cylinder.... lots of work!
                • 13974
                #82
                Click image for larger version  Name:	IMG_0171.jpg Views:	0 Size:	67.7 KB ID:	191603
                Work?... WORK??.....WORK!!!!????????
                You fed filament/resin into a Replicater; tapped some keys; pushed a mouse around; and mashed the 'enter' button. That ain't work!
                This is work:
                  • Jan 2020
                  • 1036
                  #83
                  This is work:
                  hahaha, point made!
                    • 3752
                    #84
                    David, I love when you do this photo dump. So much info in these photos. What was or is your favorite wtc you designed? What was your least favorite wtc?
                      • 13974
                      #85
                      To get all those pretty pictures posted from my hard-drive is simple: either **** me off or ask a specific question, or both.
                      Most favorite WTC: The Modular Sub Driver (MSD). We developed that on an assumption (never an assignment, we did it all on our own dime) that it was a product Bob wanted. I was wrong: the project went nowhere -- nearly a years worth of design, master and prototype tool making, iteration, production tooling, casting, cutting, and jigs and fixtures to support production. Dead-end. But our MSD was and is a great achievement. I still use them and is my preference when outfitting a new boat.
                      Bob did buy and sell a few units, but quickly decided to design, tool up, and produce his own line of WTC. And... that was that.
                      Cancer finally got Ellie, I threw my hands up in the air, and called it all a day. The MSD, our greatest achievement in my not so humble opinion.
                      Click image for larger version  Name:	IMG_1209.jpg Views:	0 Size:	45.8 KB ID:	191623
                      Least favorite WTC: The first-generation Sub Driver (SD) we created while working for Mr. Caswell -- those external hoses and manifold heads always got in the way of a tight hull closure. That, and other shortcoming led to our invention of the MSD.
                      Click image for larger version  Name:	IMG_1722.jpg Views:	0 Size:	32.3 KB ID:	191622
                        • 1647
                        #86
                        Dispite those external hoses( fixed that by using small tubes) i have found the SD a good base to work with.
                        I must say i always ripped the SD apart to rebuild it to my own specification and need.
                          • Jan 2020
                          • 1036
                          #87
                          Advice needed! I need to adhere my ballast cylinder to the ballast bulkheads. As shown i created a channel in the bulkhead for the tube to seat. Was thinking I would fill channel with West Marine 105 epoxy resin then seat the tube?
                            • 13974
                            #88
                            I would recommend clear RTV adhesive. Effects a watertight seal, has reasonable adhesive force, and will permit non-violent disassembly, if the need arrise.
                              • Jan 2020
                              • 1036
                              #89
                              Thanks David and received package with bonus!
                                • 13974
                                #90
                                Proceed, kind sir.
