Project type XXI scale 1/96
    • 13607
    #46
    Originally posted by MFR1964
    Will leave the safetyfloat out since i go for snort, hopefully it will compensate the extra conduit, if not, then the boat is loaded to the rim for going on warpatrol.
    Manfred
    As the length of the tank -- hence, the length of the conduit -- is short, and I'm assuming its dimeter will be no greater than 3/8", then it'll be an equal trade-off of volume between the removed safety float-valve and installed conduit. You're Golden!
      • 3450
      #47
      How about an external connection? I remember seeing a WTC in one of the threads here showing external power cables connected to studs coming out the sides of the ballast tank bulkheads.
      I have a customer who got a hold of one of Skip's old Albacore kits. Does anyone happen to have a scan of the instructions I could pass along to him?
        • 13607
        #48
        How about an external connection? I remember seeing a WTC in one of the threads here showing external power cables connected to studs coming out of each endcap
        An option, but not on this little model: the annular space between WTC and hull is so tight as to make that effort a waste of time.
          • 1532
          #49
          The Flu got me, it took some weeks to recover, but still building ahead, first the things i did untill the Flu hitted me.
          Since i want to both steer and retract the forward divingplanes i altered the front bulkhead to give me room for three servo's
          Placed the new servo's and made some magnetic connectors
          A fit to see if everything will fit inside the boat.
          Retracting the dive planes creates a problem, it must be possible to put the upper half on while making the connection for the retracting mechanism, glued the frontpart down
          After glueing the front part i took the jewelers saw and cutted it free.
          This is the result, you can lift the upperpart in the middle of the boat, at that moment the Flu hit me, next chapter was started after the Flu
          Made this contraption for holding both scopes and the schnorkeltube.
          The stainless tube of the schnorkel will slide over the bras tube, making the connection to snort.
          The front tube has a inlet to suck up the air while bringing the boat up
          The contraption will fit underneath the conningtower.
          Complete conningtower with all the gizmo's placed, even found some scale mesh to clad the FUMO radar, for now i'm working on the magnetic connection of the upper hull part, to be continued
            • 13607
            #50
            Outstanding!
              • 1532
              #51
              Got to feed your brain David
              Manfred
                • 1532
                #52
                Since i have chosen for retracteble divingplanes i had to make a different way for using the magnets holding the deck.
                First i made a lip for holding the magnet at the stern, this one is horizontal orientated
                The magnet at the stern on the upperdeck, i use different size of magnets, using too big of a magnet will give trouble taking the deck off.
                The front magnet is placed vertical at the bow.
                Same story for the magnet at the bow of the upperdeck, in the background you can see the mechanism for retracting the diveplanes.
                Upperdeck closed.
                Upperdeck removed from the boat, placing the magnets vertical at the bow allows me to lift that part first, the horizontal magnet follows without force
                This was a bummer, the bowpart was not propely aligned, had to cut it free and re-glued it again.
                While the bowpart was curing i made this.
                Once put together it looks likes this.
                Closed position
                Open position
                Prior to cutting open the torpedo shutters, yes, the mechanism is build to control the shutters.
                All shutters cutted open in the rough.
                First i want to get this working, later on i will make this tidy.
                This is the point where i stand now, a central hindge pin on which the shutters will pivot, first have to build some brackets to keep this contraption at it's place.
                  • 13607
                  #53
                  Upperdeck closed.
                  Closed position
                  Open position
                  H-O-L-Y C-R-A-P!!!!!
                  Manfred!!... you're out of your frig'n mind!!!!
                  Working shutter doors. Practical retracting bow planes. completely hidden rudder and stern plane linkage horns. Well... that's it. I quit. I'm taking my ball and going home.
                  Wow! The degree of my hatred for your incredible accomplishments cannot be measured. "GRrrrrr!"
                    • 1532
                    #54
                    That is, if al those things will work in the future, nothing better as to spoil your day
                      • 13607
                      #55
                      Where the hell is the 'ban' button on this damned thing???..... ****! I can't find it!!!! Foiled again!!!!!!!
                      Those irritating European's!!!!! There should be a law.
                        • 1532
                        #56
                        Maybe your beloved president can do something for you, after all he made the mexican gulf american
                        Manfred
                          • 13607
                          #57
                          Manfred
                          GGrrrrr!.....
                            • 1532
                            #58
                            Some more work on the torpedoshutters and retractingmechanism for the dive-planes
                            Click image for larger version  Name:	20241223_140759.jpg Views:	0 Size:	42.0 KB ID:	186160
                            Inserted the pre-made innerparts on the central hinge rod.
                            Click image for larger version  Name:	20241223_180055.jpg Views:	0 Size:	44.7 KB ID:	186161
                            Placed some styrene strips, used the holes in the innerparts to get a good bonding with the glue.
                            Click image for larger version  Name:	20241223_180122.jpg Views:	0 Size:	54.9 KB ID:	186162
                            The aim will be this much movement, it should be about 8mm max.
                            Click image for larger version  Name:	20241228_130536.jpg Views:	0 Size:	54.1 KB ID:	186163
                            Gave the shutters some paint because when spraying the boat i can't reach at certain places in the bowpart.
                            Click image for larger version  Name:	20241228_130551.jpg Views:	0 Size:	56.0 KB ID:	186164
                            Pretty much the same story at the bowpart
                            Click image for larger version  Name:	20241228_130812.jpg Views:	0 Size:	54.4 KB ID:	186165
                            Made the brackets which will both hold the mechanism for the shutters and dive-planes.
                            Click image for larger version  Name:	20241228_135835.jpg Views:	0 Size:	57.8 KB ID:	186166
                            Placing the mechanism which will control the retracting action, this will be the position when the bow-planes are retracted.
                            Click image for larger version  Name:	20241228_135845.jpg Views:	0 Size:	57.1 KB ID:	186167
                            Extending the bow-planes will happen in this position.
                            Click image for larger version  Name:	20241229_135429.jpg Views:	0 Size:	51.9 KB ID:	186168
                            Made some slits in the tubes to receive the rods of the upper part containing the retract mechanism.
                            Click image for larger version  Name:	20241229_135558.jpg Views:	0 Size:	55.6 KB ID:	186169
                            Made a drill- jigg to dril the holes through the shafts of the upper mechanism each time the same way.
                            Click image for larger version  Name:	20241229_140323.jpg Views:	0 Size:	52.5 KB ID:	186170
                            Placed the stainless rods, these will slide in the previous made slits.
                            For now i have to make a make-shift steering contraption and start testing if everything will work as intended, to be continued.
                              • 13607
                              #59
                              GGrrrrr!.....
                              Shutter doors, retract and functional bow planes, internal linkages for the rudder and stern planes... what's next!!???? You're taking me back to school, pal.
                                • 3667
                                #60
                                Manfred,
                                You are a flipping show off, over achiever, and a I don't know what else to call you. Amazing work my friend. Look forward to what is next and I will be keeping notes on what you do.
                                Tom
