Project type XXI scale 1/96
    • 1552
    Did some research on this boat first before i can start cutting away, got me a nice pdf of this type of boat from Rossler
    Click image for larger version  Name:	20241104_172118.jpg Views:	102 Size:	46.1 KB ID:	184640
    Click image for larger version  Name:	20241115_145849.jpg Views:	92 Size:	44.6 KB ID:	184641
    These are the items David has send me, she's not that big, but hey!!, it's a type XXI, and at this scale i can sharpen my skills
    Click image for larger version  Name:	20241104_172225.jpg Views:	91 Size:	49.7 KB ID:	184645
    Click image for larger version  Name:	20241104_172253.jpg Views:	92 Size:	53.4 KB ID:	184643
    Drilled some floodholes into the rearpart, and did a dryfitt with the shafts.
    Click image for larger version  Name:	20241104_220003.jpg Views:	90 Size:	51.6 KB ID:	184644
    Made the effort of changing all the rods to metric, much easier to play around with them.
    David has chosen the kiss way of steering the divingplanes and rudder, i want to try to hide them from sight, if that fails i can always go back to the way David did.
    First i will build the components i need to make this happen, and do some testing if it's worth the effort, to be contunued.
    • 1552
    Hiding away the steeringrods has been more work than expected, pictures
    This was a scary cut, since i have only one rearpart, it was needed to make room for my contraption.
    All basic components to hide the steering of the diveplanes
    All components together, more than enough play on the divingplanes
    Roughly oversized prior for making it fit.
    Next scary thing, for steering the rudder i had to hog out the rearpart very carefully, so that i could place a grooved pully and a small o ring.
    Here you can see the o ring from the inside.
    This piece i made to get the o ring under tension, enough to get the rudder moving.
    The trick is, by using just enough tension on the o ring, you can turn the rudder, for now it is fastened with some superglue and bakingsoda, i hope the micro servo can handle the force needed to move the rudder, if not i have to find another solution.
    The contraption with the divingplanes is made to fit the opening and will be glued tight with some 2K glue to fill in the openings
    Here you can see the steeringrods to make things happen, it's tight, but that was expected.
    For servicing the rearpart i will make a magnetic connection, so if needed the rearpart can be taken from the hull and serviced.
      • 3564
      Manfred you are a genius.
        • 13749
        Manfred, I hate you!!!!
          • 3564
          How about using a bevel gear system for the rudder? Click image for larger version
            • Oct 2017
            • 1007
            Thats too loosely fitting for proper steering. Id use a miniature belt drive,too
              • 3564
              Originally posted by MFR1964
              Click image for larger version  Name:	20241106_215829.jpg Views:	35 Size:	52.1 KB ID:	184766
              Click image for larger version  Name:	20241109_133857.jpg Views:	35 Size:	52.9 KB ID:	184767
              maybe you could fabricate a belt tensioner, put the front pulley on a small jackscrew so you adjust the tension.
                • 1552
                S[mply a guy who want to see what is possible or not
                  • 1552
                  Always a pleasure to tease you
                    • 1552
                    Don't make it too complicate, stays the fact if the servo can pull that more force to turn the rudder, we will see in the future
                      • Oct 2017
                      • 1007
                      Manfred, are you using the bow planes at the stern?
                        • 13749
                        Mission accomplished, sir. Again, you take me back to school. You're the most inovative guy I've had the pleasure of knowing in decades! I'm overrated... you are the real deal.
                          • 1552
                          Yup, at this scale they have to move, if possible retract, this will be a adventure on it's one, but where running ahead, all things step by step
                          Manfred
                            • 1552
                            We both stand on the shoulders of other gifted builders David, simply showing what is possible or not.
                              • 3564
ID:	184804 Click image for larger version
