    Next I will clean up the cut lines. David, any advice on cleaning up the Kerf would be appreciated!
    Just run a knife-edge along the side of the cut, which will cut/snap off hanging shards of kerf.
    Replace plastic lost to kerf with. 040" (or thereabouts) strips of styrene.
    (10 per side every 63MM), the Hull screw down I will cut from a Torpedo Tube
    Will be 3D fabricating Hull Taps as I clean up the cuts
    Highest RPM
    YEAH, BUDDY! kick-ass MF'er!
    (starting to like this newb)
    The Horrible
    Highest RPM
    Lowest speed setting?
    Cutting time 15 minutes per side
    Success! Thankyou David for passing on how to this! Click image for larger version  Name:	IMG_1585.jpg Views:	9 Size:	90.1 KB ID:	174897
    Excellent. How long did it take?
    You taking notes, Casey????!!!!!
    I am at that.
    Most of the Kerf fragments break away using my thumbnail
    Now that the Diamond Wheel worked flawlessly, I will link them. Remember to not push the wheel too far in, keep an eye on that, the center of the wheel is thicker then the cutting wheel which is only .60 MM thick.
    I want to remind everyone following this as David said; DO NOT MOVE THE CUTTING WHEEL AGAINST ITS ROTATION!!!!!!!!!
    Eeeeeuuuup.
    Insert three plastic shims of kerf thickness, tack glue in place, and proceed with cutting the other side.
    Idiot!
    LOL!, basically what I did
    OK!
    Hard parts done. Now. Finish that sucker!
