    Thanks David, yes, Styrene just arrived!, lol! This look better? Click image for larger version
    No!
    What the hell were you thinking?
    You thought making the corners within the too tall limber holes at their tops match the form of the corners at the bottom would fix these awful sphincter looking holes???
    Damnit!
    Rebuild with CA-baking soda grout within the holes top edge to reduce their height. Fine-tune the holes with files, sanding sticks, sandpaper twists of #240 sandpaper and god-knows-what to get them to proper shape.
ID:	175007 Click image for larger version
ID:	175008 Click image for larger version
ID:	175009 Click image for larger version
ID:	175013 Click image for larger version
ID:	175014 Click image for larger version
ID:	175015 Click image for larger version
ID:	175016 Click image for larger version
    Oh! Forgot to add these shots to show how to induce a tight radius into strip stock using a pinch-stick. File this trick away for future use. You're welcome!
ID:	175018 Click image for larger version
ID:	175019 Click image for larger version
    You people!
    When I use Styrene on horizontal cut line how should I lay it down? Can I use Nitro Stan Putty?
    Printing and affixing Hull Tabs Click image for larger version
    Would it kill you to simply bend some .030" sheet styrene to the proper radius. Jeeez!
    This complexity warship HAS TO STOP!
ID:	174995 Click image for larger version
ID:	174996 Click image for larger version
ID:	174997 Click image for larger version
ID:	174998 Click image for larger version
ID:	174999 Click image for larger version
    And tighten up those limber holes at the bow. An artifact of kit tool design rendered them too tall.
ID:	175001 Click image for larger version
    Task Master
    I am going to use Prop from Danny, did not know Bob still sells them
ID:	174975Nice brass prop and shaft.
    Fabricating magnetic hull closure parts Click image for larger version
    Bob has brass props.
    Will you be using the kit's prop?
ID:	174935Here you can see the curved tab better
    Tab is rotated 90 Degrees for printing
    First test hull tab Click image for larger version
    Fabricating tabs Click image for larger version
Name:	Image 10-14-23 at 3.46 PM.jpg
    Will do David, thanks
