1:72 Los Angeles
  • SSBN659
    • 417
    #106
    Here is a file I pulled of the web but it looks strange. I'm trying to form the forward and after hulls but I can't confirm the dimensions. Can anyone point me in the right direction?
    Will Rogers
    SSBN659
      • 13475
      #107
      Will Rogers
      SSBN659
      I can do more than help. Send me your address and I'll fix you up.
        • 13475
        #108
        Originally posted by spankey
        Next Update,
        Just soldered up a prop linkage from the shaft on the hull to our Most Esteemed Leader's WTC. As you can see, the WTC is presently positioned aft so that the Center of the Ballast tank is ~1 inch forward of the center of the boat (lengthwise). Thanks Admiral Greenman.
        With no battery installed, the CG is somewhere near the aft 1/3 of the boat.
        I'm planning on a 6 Volt, 14 AH Werker Gel cell, unless someone wishes to correct the abhorrent error of my ways. This cell weighs ~6.1 lbs, which should drive the dry CG into the forward 1/3 of the boat.
        Is there a rule of thumb for where the CG should be in relation to the Center of the Ballast tank, which is positioned as stated above?
        [ATTACH=CONFIG]21673[/ATTACH][ATTACH=CONFIG]21674[/ATTACH]
        CG at the longitudinal center (or thereabouts) of the ballast tank.
        • SSBN659
          • 417
          #109
          Thanks in advance for your help David. You always come through when I need help. My address is:
          31048 S Canyon Vista Way
          Oracle AZ 85623
          Will Rogers
          SSBN659
          • Sam Victory
            • Sep 2021
            • 391
            #110
            • SSBN659
              • 417
              #111
              Thanks Sam.
              Will Rogers
              SSBN 659
              • SSBN659
                • 417
                #112
                Thanks to David and Sam for their help I'm ready to start a model of USS Tucson SSN 770. I'll do this in a separate thread.
                Will Rogers
                SSBN659
                • wlambing
                  • Nov 2020
                  • 373
                  #113
                  Only 3 MBTs in the bow! So, only 6 MBT vents. The rest were aft end, behind the Engine Room, in the tail cone.
