USS Tucson
  • SSBN659
    • 418
    #151
    Started work on a prop for Tucson. Looked closely at what David posted, the Prop Shop UK prop I bought from them years ago for my Will Rogers model, and various other drawings.
    The pictures tel the story.
ID:	175344 Click image for larger version
ID:	175345 Click image for larger version
ID:	175347 Click image for larger version
ID:	175348 Click image for larger version
ID:	175350 Click image for larger version
ID:	175351 Click image for larger version
ID:	175353 Click image for larger version
ID:	175361 Click image for larger version
ID:	175357 Click image for larger version
    The final shows that I came close, but not close enough, so back to the shop for a second try using what I learned making this prop.
    Will Rogers
    SSBN659
    • SSBN659
      • 418
      #152
      Still working on the prop. Getting closer but not quite there yet. These shots are try #3. Hopefully try #4 will be satisfactory. Photos 3 & 4 are a dry fit showing where more work is needed. I will eventually get it right.
ID:	175585 Click image for larger version
ID:	175587 Click image for larger version
      Will Rogers
      SSBN659
        #153
        Just sharing.....
        Jig for holding the blades in place when soldering
Name:	Akula (95b).jpg
Name:	Akula (98b).jpg
Name:	Akula (96b).jpg
Name:	akula (97c).jpg
        Using sand to adjust the propeller allows for fine-tuning: it both secures the blade during heating and facilitates minor adjustments.
Name:	Akula (662).jpg
Name:	Akula (661).jpg
Name:	Akula (663).jpg
Name:	Akula (665).jpg
Name:	Akula (666).jpg
        • SSBN659
          • 418
          #154
          Wow, you just gave me a blinding flash of inspiration!
          Many thanks for sharing this Bart,
          Will Rogers
          SSBN659
          • Ken_NJ
            • Sep 2014
            • 1006
            #155
            Really nice job! Prop is looking great!
            • Davjacva
              • Nov 2022
              • 408
              #156
              The prop was great, but to me, the star of the show was that jig. What a piece of art.
                #157
                Bart's gizmo? If so, I could not agree more. That was Loren Perry quality engineering there.
                • SSBN659
                  • 418
                  #158
                  After several attempts at making the prop I still haven't been satisfied with my results. I'll keep trying but as a backup I wonder if anyone out there is able to make a 2" diameter seven blade ringed prop using this new fangled 3D printer technique?
                  Will Rogers
                  SSBN659
                    • 3769
                    #159
                    Keith Bender - propmeup1@verizon.net
                    He does a fine job on creating props. Very nice to work with!
                    • SSBN659
                      • 418
                      #160
                      Thanks Tom, Keith no longer making ringed props. I sent notes to Prop Shop UK and to Loyal Hanna Dockyard but haven't heard back. Back to the workbench.
                      Will Rogers
                      SSBN659
                        #161
                        Will Rogers
                        SSBN659
                        Hi Will,
                        I took a look online and found something that might be useful. The person will be capable of scaling the props to your desired dimensions. It's important to discuss with them which resin they'll use, as some resins can be brittle."
                        https://www.ebay.com/itm/26550458319...kAAOSwWepelmgy
                        Grtz,
                        bart
                        • SSBN659
                          • 418
                          #162
                          Thanks again Bart. I sent a request to the fellow to see what he might be able to do for me. Haven't heard back yet.
                          Will Rogers
                          SSBN659
                          • SSBN659
                            • 418
                            #163
                            It's not easy trying to make it look like you know what you are doing. I gave up on brass for my ringed prop and switched to polystyrene. Also found a more accurate method of making a target for a seven blade prop because 360 can be evenly divided by all numbers 1 thru 10 except for 7.
ID:	175850 Click image for larger version
ID:	175851 Click image for larger version
                            This is the jig I made for cutting slots in the hub for the blades.
ID:	175853 Click image for larger version
Name:	IMG_0078 2 copy.jpg
                            Getting the ring and blades attached was a challenge but I think it came pretty close.
ID:	175855 Click image for larger version
                            I never heard back from my queries to third party about purchasing a prop so I'll stick with this one for now.
                            Will Rogers
                            SSBN659
                            • SSBN659
                              • 418
                              #164
                              Could have saved a lot of time if I had seen this earlier.
                              Oh well, lesson learned the hard way, now back to work.
                              Will Rogers
                              SSBN659
                              • SSBN659
                                • 418
                                #165
                                Not much work going on due holiday and travel but this prop is finished.
                                Happy holidays!
                                Will Rogers
                                SSBN659
