3D printed 1/48 Thresher
    • 1572
    #76
    Oh, you meant the model. Duh!
      • 821
      #77
      Thanks David! That is exactly what I needed. Casey, I appreciate the effort.
        • 821
        #78
        Non-skid on. It will be more subdued as I progress.
        I also have the waterline marked on it.
          • 13697
          #79
          ... and don't over-state the difference in shade between non-skid and hull. It should be barely seen. I recommend a mist-coat of the black over the non-skid to subdue it more. It's much too distinct as is.
            • 821
            #80
            Better...
              • 13697
              #81
              Better...
              WHY DON'T YOU JUST PAINT IT WITH A POWER-WASHER LAODED WITH BLACK PAINT, AND SET ON 'KILL'??!!!!.....
              No! You ruined it. You can't do good work with a rattle-can, damnit! Invest and learn how to use a proper single-action air-brush. Now your THRESHER has been fly-specked to death.
              Nuts!
              Wet-sand that goop off the top of the hull and sail planes and start again.
              Go to Harbor Freight and get one of those fifteen-buck touch-up air-guns and a Paasche H-model air-brush.
              You're too good a talent to be slinging paint with fire-crackers!!!!
              Finesse, man.... FINESSE!!!!
              Paasche H-1AS Single Action External Mix Airbrush Set with 0.65 mm Tip (webstaurantstore.com)
              You people!
ID:	154991Click image for larger version
ID:	154992Click image for larger version
ID:	154993Click image for larger version
ID:	154994Click image for larger version
ID:	154995Click image for larger version
ID:	154996Click image for larger version
              The Horrible
                • 821
                #82
                I have an Iwata Neo airbrush and I can use it. Yes, the base black paint was a rattle can thus the reason I misted over the non-skid with it. I suppose I could have sprayed the paint into a container to then use in the AB or decanted the whole can but it never crossed my mind. There are still quite a few layers to go before this is done. All is not lost...besides, I am not out to de-throne the master but I do consider it a lesson learned.
                  • 13697
                  #83
                  Click image for larger version  Name:	20211026_103114.jpg Views:	0 Size:	46.8 KB ID:	154999
                  Oh... enough of the humble-pie stuff. This is competitive model-building, second-placers get skinned and eaten! Man up! You're in the Big Leagues now, pal.
                  I expect to eventually be de-throned. It's inevitable. But, to do so you'll know you've been in a fight -- and it was all worth the knocks and miss-steps. You can be so much better at this painting thing than you know. The only time I grant ANYONE here a positive comment on their work is when they actually EARN it. No safe-rooms or time-outs here! So, break out your Iwata (whatever the **** that is?!), decant some of that rattle-can goo, and start practicing on a test article with a real, honest to God, paint applicator.
                  I'm sure you have unpainted hulls standing in shop corners all over the place by now -- use one of those to test out your air-gun/brush. Play with it, try different masking techniques, paint chemistries, pressure-distance-thinning ratios, etc. Go nuts!
                  Experiment!
                  Get to it.
                    • 821
                    #84
                    Clearly if I was afraid of your "eloquently worded critiques" I wouldn't post anything here but it is all for the sake of improvement and clearly practice does make one better along with the support of others. If I learned nothing from this that would be tragic indeed. Thank you for being my biggest critic. Now, back to work...
                      • 13697
                      #85
                      There you go. That's the stuff!
                      Poet And Don't Know It
                        • 13697
                        #86
                        Most professional critics are masters of spouting off about stuff they themselves can't do, or do poorly (Ellsworth Toohey comes to mind), and are less than worthless, they are destructive -- I have nothing but contempt for those cocktail-party, articulate, loud-mouths.
                        But, a Master of a craft, who is also a critic on that subject (Bob Ross comes to mind), yeah. His words have merit. His critique is not casual comment, it's instructive.
                        Student of the Craft and Critic
                          • 821
                          #87
                          How effective is the anti-foul paint at preventing the nasty tannish marine growth from forming?
                            • 1572
                            #88
                            I really don’t think I’ll be punching a hole into a can of spray paint.
                              • 821
                              #89
                              Only time I have was with a can of clean metal primer that clogged up on me and the stuff was $17 a can off of Amazon so I decanted it and sprayed it through my airbrush. Was messy but it worked.
                                • Oct 2017
                                • 999
                                #90
                                I use a prepared cleaned out old sprayhead with a long silicon pipe instead of the tight nozzle installed. Then spray out as much paint as i need into a glass and leave that open some time to release any gas left before closing that glass. Less messy
