3D printed 1/48 Thresher
    • 821
    I have started printing a 1/48 scale Thresher. It will be almost 70" long with just under an 8" beam. The bow just came off the printer. This one is being done in ABS+. It turned out very good.
    As a kid I remember reading a book I found in the school library about the Thresher, it's tragic loss and subsequent finding of the wreckage and I was fascinated. I later found out that my ex-wife's sister was engaged to one of the crew members which helped cement in me the tragedy of an event that happened a mere two months before I was even born. For a very long time I have wanted to make a model of the Thresher, not out of a some morbid curiosity but as a remembrance of those 129 souls. May it never happen again. Thank you Bob for putting out the files for this boat aka the Permit class.
    • 13697
    A tease. Here's on in 1/72nd.
ID:	151986Click image for larger version
ID:	151987Click image for larger version
ID:	151988Click image for larger version
      • 821
      Stunning as always sir!
      Few questions for you if you don't mind?
      1. I have read that the Thresher had a 5-blade prop while the rest of the boats in the class (Permit) had quieter 7-blade props. Is that true?
      2. Do you know what diameter the prop was on the Thresher by chance?
      3. Did the Thresher have anti-fouling paint on the lower hull and if so was it at the water-line or middle of the hull?
      Thank you in advance.
        • 13697
        Not at all, sir.
        1. I too have read that, but have never seen photos of the THRESHER (a Government design) outfitted with the five-bladed wheel. Likely -- as SKIPJACK, THRESHER, The early SSBN's, and STURGEON class used the same S5W propulsion plant -- the THRESHER had the five-blader for comparative speed-runs. The new wheel was quieter (a premium characteristic), but less efficient.
        2. The seven-blader is about 14-foot in diameter.
        3. Until later in the last century the government yards on occasion used a black anti-foul paint. Yet there are pictures of the PERMIT launched from Mare Island (a government yard) with anti-foul red from centerline down. I may be wrong, but at one time I believed that THRESHER, a Portsmouth (government yard) boat was launched with black anti-foul, but I've never seen a color shot of the boat on the ways to tell if it was all back, or had anti-foul red from waterline down, or centerline down. Still remains a mystery to me.
        At time of loss I think THRESHER had anti-foul red from centerline down.
        Sorry. Short answer is... I don't know!
        However, all that said: there is a video of the boat sliding down the ways where there does appear to be a color/shade demarcation line at centerline. Not clear enough to make a definitive call.
        One more thing, in most of the video of the boat cruising on the surface, topside was painted in the 'Pacific' scheme.
          • 821
          Not at all, sir.
          Excellent information! Thank you.
          What is a 'Pacific' scheme? First time I have heard that term.
            • 13697
            Here you go:
            What Color Would be your guess? - The Sub-drivers Forum (rc-sub.com)
              • 1572
              Money says I checked out the same book. “The Death of the Thresher” by Norman Polmar.
                • 821
                It was over 40 years ago so it would have been copyrighted before 1981. More than likely it was "The Thresher Disaster: The Most Tragic Dive in Submarine History" by John Bentley published in 1975.
                  • 1572
                  Polmar’s book was first published in 1964.
                    • 821
                    OK. Then it could have been. I tried to find the date it was first published but showed it was much later.
                      • 821
                      The first three sections of the hull are printed. The detail of the files is exceptional to say the least and the parts fit together very well. I have spent only a minimal amount of energy sanding them to the point that one good coat of high fill primer (Finish 1) will be all that is needed before paint. I am going to make brass catches to slide lock the upper hull to the lower hull to help lock the two together through the center. The ABS+ is some good stuff and the Ender 5+ is printing great. The way the parts are designed there is minimal if any need for support structures. I hate wasting filament on supports. I also downloaded and printed a 5-blade propellor (3-1/2") as I decided that is what I am going with. It may not be exactly true to the original prop but I really don't care. It will work. After I hit it with the primer it will make it very strong.
                      Click image for larger version  Name:	20210807_142054.jpg Views:	0 Size:	47.5 KB ID:	152135
                      Click image for larger version  Name:	20210807_143715.jpg Views:	0 Size:	44.3 KB ID:	152136
                      Click image for larger version  Name:	20210807_143725.jpg Views:	0 Size:	39.9 KB ID:	152137
                        • 1572
                        I believe it was republished in 1981 and after 2000.
                          • 821
                          Hey David, can you tell me a little more about this hatch detail?
                            • 13697
                              • 821
                              Excellent! Thanks again.
