  • Monahan Steam Models
    • 755
    #76
    Amazing work. The many hours put into the CAD model really shows. Can’t wait to see more.
      • 1791
      #77
      Really nothing special....Elegoo Mars, Anycubic ABS-Like resin, and Chitubox with standard settings. For the bove prints I let Chitubox do all the supports without any editing.
      DrSchmidt!
      Thank you very much for the return information! Again, can't say enough about your work!!
      • DrSchmidt
        • Apr 2014
        • 921
        #78
        Still working on details of the interior of the Type XXIII for my 1:35 Bronco Kit....."Zentrale" with the dive plane controls.
        • DrSchmidt
          • Apr 2014
          • 921
          #79
          Still designing the Type XXIII interior. Putting the finishing touches on the ventilation ducts and the ventilation manifold for the batteries. During charging the batteries produced hydrogen that had to be removed by the ventilation system. So there were four tubes running above the battery cells that collected the hydrogen though tiny tubes that were connected to the collection tubes. Tedious work....
          • DrSchmidt
            • Apr 2014
            • 921
            #80
            Continuing with the interior and equipment of the torpedo room for my 1:35 Bronco XXIII
            • DrSchmidt
              • Apr 2014
              • 921
              #81
              Designing the hatches for my Txpe XXIII submarine project. Even with blueprints one can spend a few evenings to get them right...
              • jphatton
                • Jan 2021
                • 84
                #82
                Thanks very much for posting the step by step progress on your CAD and 3D printed model interior. The level of research and effort that has gone into this project si very impressive.
                Indeed one of the thing's of I've found very satisfying with CAD work is translating drawings, photos and often a bit of guesswork into a 3 dimensional model. As you note this often this takes a few iterations to get it right.
                Out of curiosity what CAD software are you using?
                • DrSchmidt
                  • Apr 2014
                  • 921
                  #83
                  ViaCad Pro
                  • DrSchmidt
                    • Apr 2014
                    • 921
                    #84
                    Conning tower. Hatch done, next attack periscope. There are plenty photos but all look differet. The XXIII plans help a little bit and I found some blurry cross sections. So what I show here is my best guess approxiamtion.
                    • DrSchmidt
                      • Apr 2014
                      • 921
                      #85
                      Type XXIII submarine: That was a complicated one.....the cable pull mechanism of the periscope. The periscope was raised and lowered by a cable winch in the control room. The cable ran over various pulleys to the periscope. Intricate arrangement under the roof of the conning tower.
                      • DrSchmidt
                        • Apr 2014
                        • 921
                        #86
                        A Type XXIII submarine conning tower. Adding bits and pieces....speaking tubes, switch boxes, plugs and rheostates.A Type XXIII submarine conning tower. Adding bits and pieces....speaking tubes, switch boxes, plugs and rheostates.
                        • DrSchmidt
                          • Apr 2014
                          • 921
                          #87
                          Added the ladder and some junction boxes. Fixture for the lamp and cabling, the the CAD model of the conning tower for my 1:35 Bronco XXIII submarine kit is done.
Name:	Screenshot 2021-04-10 at 12.59.56.png
                          • DrSchmidt
                            • Apr 2014
                            • 921
                            #88
                            Conning tower done....the wiring of the switches and boxes in the isnide is a but guesswork, but it makes sense. Sits comfortably on the control room....Click image for larger version
                            • DrSchmidt
                              • Apr 2014
                              • 921
                              #89
                              Working on the deep bilge pump of the Type XXIII. It was made by Klein, Schanzlin & Becker (KSB) an to my knowlege it was a two cylinder double-action piston pump with cross heads. With respect to how it looked....few information on that side. Tried to get info from KSB, but no answer. I know that in the stren room of the type XXI the same type of pump was installed, so I took it from there....I guess it's close but becomes guesswork in the lower parts.
Name:	Screenshot 2021-05-12 at 18.12.40.jpg
                              • DrSchmidt
                                • Apr 2014
                                • 921
                                #90
                                Progress on the Type XXIII submarine galley. Added the activated-charcoal filter for the fresh water faucet right to the sink and the respective piping. Additional work on the ventilation ducts and detail work on the electrically heated pot. Getting there.....
ID:	150382Click image for larger version
