    • 13528
    #241
    Wow! Looking at those tubes made this old Torpedoman's Mate recollect the smell of grease, metal polish, the stink from roller-pockets, ****, diesel oil, and dirty socks.
    Masterful work, herr doktor!
    • DrSchmidt
      • Apr 2014
      • 1289
      #242
      Thank you very much. Took me while to get the tubes right, but it was worth the time.
      • goshawk823
        • Oct 2010
        • 260
        #243
        fantastic work on this boat. really appreciate you sharing the progress with the build.
        • neitosub
          • Nov 2021
          • 147
          #244
          Stunning build!
            • 3666
            #245
            Drooling like everyone else. When I see there is an update to this thread, I get excited to see what you are doing. Always impressive and fantastically detailed.
              • 1959
              #246
              Insane... absolutely insane! So beautiful!
              • DrSchmidt
                • Apr 2014
                • 1289
                #247
                Worked some on the torpedo tube assembly. Between the tubes and the pressure hull wall were two compressed air bottles that contained the air used to expell the torpedos. I installed both, but as the starboard bottle would have excessively blocked the view inside the torpedo room, I depicted it hollow and cut away. Like it allot!
ID:	162853Click image for larger version
ID:	162855Click image for larger version
                  • 1520
                  #248
                  That is awesome.
                    • 821
                    #249
                    Mind blowing detail!
                    • SSBN659
                      • 417
                      #250
                      Amazing work. Thanks for sharing it with us. I may have missed it earlier but what is the scale?
                      Will Rogers
                      SSBN659
                      • DrSchmidt
                        • Apr 2014
                        • 1289
                        #251
                        The interior will go into a 1:35 Bronco XXIII kit
                        • DrSchmidt
                          • Apr 2014
                          • 1289
                          #252
                          Worked a bit more on the details of the torpedo tubes. I installed the depth setting gears (blue arrow, port one is hidden). The running depth of the torpedos was set manually. Via a plate one could drive a shaft into the respective socket in the torpedo and then, via a hand crank, one could set the running depth. The gyro angle for the torpedos was set via gears (yellow arrows) and shafts via a hand crank below the gyro angle receiver (green arrow). The shooting solution was calcuulated using a "Torpedovorhalterechner" (torpedo data computer, red arrow). I also added the "Ausgleicharmaturen" (torpedo control panels, pink arrow), that were used to flood and vent the tubes. Via a angled adapter plate they were directly screwed onto the firing valves. The firing vales sat directly on the compressed air bottles. As a neat detail I added the hand crank, used to operate the muzzle doors and torpedo hatches, to the starboard torpedo hatch.
                          Click image for larger version  Name:	XXIII-234.jpeg Views:	0 Size:	68.3 KB ID:	163116
                          Click image for larger version  Name:	XXIII-235.jpeg Views:	0 Size:	63.2 KB ID:	163117
                          Click image for larger version  Name:	XXIII-237.jpeg Views:	0 Size:	63.2 KB ID:	163119
                          Click image for larger version  Name:	XXIII-236.jpeg Views:	0 Size:	66.8 KB ID:	163118
                          • goshawk823
                            • Oct 2010
                            • 260
                            #253
                            the detail in this space is mind blowing. fantastic!
                            • DrSchmidt
                              • Apr 2014
                              • 1289
                              #254
                              For those who are on Instagram - the current status with lights on: https://www.instagram.com/reel/CguiH..._web_copy_link
                              • neitosub
                                • Nov 2021
                                • 147
                                #255
                                Superb! The lighting makes me feel like walking through a museum exhibit!
                                Nate
