. Bill Bibeault Bronco Type XXIII Build
  • cgbillb
    • May 2018
    • 182
    #46
    How not to add the putty, too many air spaces but not to worry it all came of when I pulled the tape off, after sitting all night. Click image for larger version  Name:	30.jpg Views:	1 Size:	77.3 KB ID:	128150
    Click image for larger version  Name:	31.jpg Views:	1 Size:	148.2 KB ID:	128151
    Guess I did not RTFI
      • 13973
      #47
      Once you have cut and filed that putty to shape coat it and the union between it and the model with thin formula CA. This to buck up the putty and insure a tight bond between it and the edge of the hull.
      Good job on the marking-cutting jig, Bill.
      Manfred is crazy good at this stuff, but his model access approach is way above my (and your) league. KISS.
      • cgbillb
        • May 2018
        • 182
        #48
        Tom
        I did not do this
        Acetone bath and scrubbing followed by a very warm sudsy water bath. Rinsed and let dry.
        I did not do this
        And scrub all the plastic parts with scouring powder and water followed by a good rinsing. The injection forming process leaves oil on the parts surfaces and that will bugger up bonding and painting.
        Guess I did not RTFI very well
        After coffee will wash the hull, and try again, good think I got a large can of Evercoat and all winter to build the U-2326 and have a type VIIC to build as well
        Bill
        • cgbillb
          • May 2018
          • 182
          #49
          OK gave the U-2326 a bath as in the RTFI and put putty on will let try for a few hours.
          David if I read the RTFI right, I need to put CA on as I pull the tape off? So the putty is just a filler and the CA is the bonding ?
Name:	Making Up The Kerf - The Sub-drivers Forum.jpg
            • 13973
            #50
            That's right, Bill. Easy when pulling the tape or you'll break the putty away -- that putty that did not yet receive the CA to bond it tightly to the styrene plastics edge.
            And good job getting those big pictures to post in the thread.
            • cgbillb
              • May 2018
              • 182
              #51
              Thanks Have it after I RTFI have portside done came out great will do the starboard side after the CA dry's good
              Thanks' again
              Bill
                • 3751
                #52
                Bill,
                The cutting the hull is one of the major hurdles people have to overcome. You went for it and did a fine job!
                Putting the glaze in-between two pieces of tape is challenging. That being said you are getting it done.
                As I recall (take that with a grain of salt), cutting the hull and trimming are the two biggies for this sub. Trimming is a bit of patience, but not as technical as cutting the hull (for me at least). So, that being said, you are on your way to finishing this sub!
                Tom
                • cgbillb
                  • May 2018
                  • 182
                  #53
                  Tom
                  Thank you yes it had me worried, about doing it. I just got both sides done and will let them dry till tomorrow. Thanks to you and what is his name, I got thru it looks good. Have a type VII U-977
                  To do a little later. Thank you Tom and David for your help and build logs on getting me thru this part, now on to the rest of the build.
                  Bill
                    • 13973
                    #54
                    Tom
                    Bill
                    This ain't BUILDING! The building was done by a big heavy set of steel tools. You're assembling! (and doing a fine job of it, too).
                    Get back to work!
                      • 1647
                      #55
                      Bill, first get your Type XXIII build, that alone will be your goal for now, building a big scale type VII is a different story, i also own a type VII but at 1:35 scale, this beast is BIG!!!! and a handfull to handle.
                      • cgbillb
                        • May 2018
                        • 182
                        #56
                        Manfred
                        Yes you are right one of my goals is to LEARN, how to build a U-Boat , I have auto-cad drawing's coming (2-3 months out) for my U-505 also that will be my dream U-boat at 1/48 scale around 65"
                        But after my U-2326 and U-977
                        Bill
                          • 3751
                          #57
                          Get back to work!
                          David, don't make me break out the Merriman-Webster dictionary again!
                          Bill, build away!
                            • 13973
                            #58
                            Hey, Bill. Something for you to watch. A blast from the past!
                            • cgbillb
                              • May 2018
                              • 182
                              #59
                              Tom
                              I did have to break out my Dictionary, well google it thanks.
                              wow you are a old dude, I did watch it with my coffee,thanks now back to work,
                              Manfred
                              Love your rudder-plane linkage, The U-505 will have something like that.
                              Have a great days guys
                              Bill
                                • 13973
                                #60
                                Tom
                                Manfred
                                Bill
                                Gee … thanks!
