Victor III
    • 3727
    #286
    Outstanding! The buoy and hatch are they 6 pieces and assembled like slices of a pie or one piece?
    • bwi 971
      • Jan 2015
      • 940
      #287
      Pie casted in different colored resin
      "Samuel Smiles"
        • 3727
        #288
        Brilliant!
        • bwi 971
          • Jan 2015
          • 940
          #289
          Yes……the most complicated resin cast I ever did worked out beautiful. 13 cores were inserted.
          Pictures right after demolding.
          Grtz,
          Bart
          "Samuel Smiles"
            • 13908
            #290
            A remarkable achievement, sir. True model-building on display here!
              • Oct 2017
              • 1034
              #291
              What is this? PU?
              nicely done!
              • bwi 971
                • Jan 2015
                • 940
                #292
                What is this? PU?
                nicely done!
                thks yes it is
                "Samuel Smiles"
                • bwi 971
                  • Jan 2015
                  • 940
                  #293
                  Thks David!
                  "Samuel Smiles"
                  • bwi 971
                    • Jan 2015
                    • 940
                    #294
                    Going back and forth on the tandem propeller. Latest attempt.....I will make a test bench to try her out in the water.
                    Grtz,
                    Bart
                    "Samuel Smiles"
                      Very nice Mate. That tail cone is a WORK of ART! (reaching for tin helmet).
                      • bwi 971
                        • Jan 2015
                        • 940
                        #296
                        Recently I started making live videos of the work in the shop for those who are really bored.
                        I received some questions on the stern tooling so I made a video on demolding and explaining the use of the cores and stuff.
                        Here is the link, https://fb.watch/2KO3ft8_Ih/
                        Grtz,
                        bart
                        "Samuel Smiles"
                          Who is the handsome devil in that video? I didn't realise that you had hired a professional actor!
                          • bwi 971
                            • Jan 2015
                            • 940
                            #298
                            You mean the vagrant Lookalike?
                            Grtz,
                            Bart
                            "Samuel Smiles"
                            • bwi 971
                              • Jan 2015
                              • 940
                              #299
                              Last of the outfittings.
                              Spent most of the yesterday on designing, tweaking of the fwd dive plane until I had a working prototype.
                              The plane is a “flap rudder” type or “multi-section” rudder. The hinged aft section gives the rudder an extra control surface therefore enhances its efficiency.
                              When the helm is applied the angle of attack of the main control surface changes (working of a normal rudder), in addition the angle of attack of the flap also changes.
                              If the main rudder rotates 45° the flap turns an additional 45°. The flap is making a 90° angle to horizontal.
                              Pictures showing both 0° and 40°
                              Grtz,
                              Bart
                              "Samuel Smiles"
                                • 13908
                                #300
                                A practical articulated control surface?...
                                You nut! You European's are a scary bunch.
                                Amazed
