Victor III
  • bwi 971
    • Jan 2015
    • 902
    Thks David.......I need A LOT more experience before I have a go at this........you have to know exactly what you are doing regarding the thickness of the gelcoat, resin, and laminates that will be applied on the other non-lip part of the hull. Then and only then you can you can determine the offset of the thin indexing board.
    I should have known there is no hocus-pocus way to do this………just practice.
    (and there he goes, back to his basement, humbly shaking his head, mumbling “when I grow up…….” )
    Gtrz, Bart
    "Samuel Smiles"
      • 12311
      Gtrz, Bart
      Horse-****! It's easy: indent the lip 3/32" to the hull master (the ideal wall thickness of r/c submarine hulls) and when you eventually lay up your other hull half in its tool you either grind the inside to a wall thickness of 3/32" or lay up the required strips of glass to achieve the desired wall thickness. With practice you quickly determine the weight and number of laminates to achieve that wall thickness.
      No sweat, Bart.
      Man! That VICTOR-3 is shaping up, pal.
        Easy for him: difficult for us. Look out Bart. I sense a challenge coming on.
        • bwi 971
          • Jan 2015
          • 902
          I know.....I hate him......he is always doing it......Think I will do it in the end......I’m chewing on something.
          grtz,
          Bart
          "Samuel Smiles"
            • 12311
            Ha!
            My work here is done.
            • bwi 971
              • Jan 2015
              • 902
              When I say high detail, I actually mean HIGH DETAIL.
              One of the SOKS censors (yes I went over the top, yes I’m crazy)
              Pictures were taken with the macro setting of the camera, dimensions are in mm.
              All credits to "the machine"
              Grtz,
              Bart
              Click image for larger version  Name:	P10503222.jpg Views:	1 Size:	284.6 KB ID:	128343
              Click image for larger version  Name:	P10503213.jpg Views:	1 Size:	289.6 KB ID:	128344
              Click image for larger version  Name:	P10503204.jpg Views:	1 Size:	285.1 KB ID:	128345
              Click image for larger version  Name:	P10503195.jpg Views:	1 Size:	353.9 KB ID:	128346
              Click image for larger version  Name:	P10503186.jpg Views:	1 Size:	356.8 KB ID:	128347
              "Samuel Smiles"
              • bwi 971
                • Jan 2015
                • 902
                Concentrating on the sail now. Test-fitting the SOKS and making the louvres fit.
                Grtz,
                Bart
                "Samuel Smiles"
                  Outstanding! How did you make the louvers? AND, did you cut the holes ans slots or cast them - I can't tell.
                    • 3547
                    3D printing,Skill!
                    • bwi 971
                      • Jan 2015
                      • 902
                      3D printing,Skill!
                      Oh boy....that will have the dragon unleashed for sure
                      "Samuel Smiles"
                      • bwi 971
                        • Jan 2015
                        • 902
                        Everything was done by the machine this time Scott....I only assembled the parts, made them fit.
                        The sail will be cast with the holes......louvers will be after fitted.....hatches and doors you must do yourself.
                        My idea behind it is that you can chose if you want certain pieces in open or in closed position......radar, periscopes,.....
                        Grtz,
                        Bart
                        "Samuel Smiles"
                          • 12311
                          F you, Tom!!!!!!!!!!!!!!!!!
                            • 3547
                            Oh my goodness I started laughing in a waiting room. I probably looked like a crazy person. I showed Tina your message and she laughed.
                              • 12311
                              LOL. Sorry, Tina, that your were subjected to this nasty, thoughtless, antagonistic, trolling perpetrated by your kit-assembling, robot-loving husband.
                                • 2121
                                I wonder how cheap those DLP based printers will get? Some can be had for under £200 now, although the resin is pricey. They do render superb detail.
