Victor III
    #61
    I'm currently gently rocking in a corner trying to process all this.
    Grtz,
    Bart
      #62
      I’m sorry that I vanished for a while……..”she who must be obeyed” wanted to renovate the bathroom completely. So “he who’s has no choice” neglected his hobby for over a month. But I’m fine with it honestly (**** mumblemumble).
      All necessary pieces are cut now…..allocation and dimensions are marked on masking tape. One day this pile of blocks will turn into a sub.
      Why I cut them all?….well to get the max out of the modeling board with the min amount of waste.
      I made a scheme with the dimensions needed and calculated how they will best fit in the modeling boards I had. Click image for larger version  Name:	2018-05-06 11_37_54-Berekening renshape.xlsx - Excel.jpg Views:	1 Size:	274.5 KB ID:	126222
      Click image for larger version  Name:	Labelite-cut.jpg Views:	1 Size:	382.5 KB ID:	126224
      Click image for larger version  Name:	Labelite-labeled.jpg Views:	1 Size:	409.0 KB ID:	126223
      Stern moulds.
      As you will know I like doing things complicated and like designing stuff. Here again I calculated what is the most economic thing to do (as this is not my occupation I don’t give a darn what amount of time I spent doing it):
      • Make the moulds just by pouring a vast amount of silicone into a box or
      • Make the moulds by shaping some modeling board and use a thin jacked of silicone to take the shape of the stern master.
      Both materials are expensive but the most economical was the lather….ok ok I admit I had give it a shot anyway because I liked the challenge of it and it looked like the most fun to do.
      Did it turn out ok? well it was a hell of work, it was challenging, precision was the key. I had to make dowel pins and pockets so the multiple pieces that forms the Articulated mould will fit perfectly together. The master is plain so I needed a caliber to make things hollow. The master is not provided with an index to take the hull parts I had to take that in the design too. But I think It turned out ok. Will it work? I don’t know, I will see in a later stage if it works , if it does not…..we had fun anyway.
      Dowel pins and pockets (clearance between them is 0.02 mm) I think I made close to 50 pc of them know....and counting Click image for larger version  Name:	Dowel-pin- fabrication-001.jpg Views:	1 Size:	627.9 KB ID:	126225
      Caliber mould, with integrated dummy index lips Click image for larger version  Name:	mould-caliber-001.jpg Views:	1 Size:	491.4 KB ID:	126226
      Caliber mould end plate, after casting it will become one with the caliber and fitted on the mould masters to make the cast of the part hollow. Click image for larger version  Name:	mould-caliber-base.jpg Views:	1 Size:	428.6 KB ID:	126227
      The articulated caliber mould in different stages of assembly Click image for larger version  Name:	muld-caliber-004.jpg Views:	1 Size:	251.2 KB ID:	126228
      Click image for larger version  Name:	mould-caliber-003.jpg Views:	1 Size:	440.8 KB ID:	126229
      Click image for larger version  Name:	mould-caliber-004.jpg Views:	1 Size:	389.2 KB ID:	126230
      Mould master base plate, the silicone sleeve inside need to be casted in both mould master halves, so I needed a base plate to do it. Click image for larger version  Name:	Mould-base-plate.jpg Views:	1 Size:	423.3 KB ID:	126231
      Base plate fitted to one of the master halves Click image for larger version  Name:	mould-part-halve-001.jpg Views:	1 Size:	383.6 KB ID:	126232
      Click image for larger version  Name:	mould-part-halve-002.jpg Views:	1 Size:	451.1 KB ID:	126233
      the articulated master mould assembly Click image for larger version  Name:	mould-masters-003.jpg Views:	1 Size:	477.4 KB ID:	126234
      Click image for larger version  Name:	mould-masters-004.jpg Views:	1 Size:	498.3 KB ID:	126235
      All parts of the moulds Click image for larger version  Name:	Articulated moulds.jpg Views:	1 Size:	423.5 KB ID:	126236
      Thats it for now,
      Grtz,
      Bart
      • Peter W
        • May 2011
        • 511
        #63
        Holy crap Bart they are some pretty moulds !!
        Peter
          Amazing stuff Bart. Maniac is jsut not a good enough word for you! I can't wait to see more of this.
            #65
            Peter
            Thks Peter, they are over the top, but this stuff I realy like doing.
            Thks Scott.....bow section is up next....ETD Thursday next
            Grtz,
            Bart
              • 13997
              #66
              I'm totally impressed!
                • 2642
                #67
                very neat. have they been milled out with a CNC router/mill?
                  #68
                  Andrew don't mentions those words here........you will wake up the killer rabbit.......nonono …… I used a hammer and chisel....honestly Mr rabbit I did.....never heard of those things andrew mentioned.
                    • 13997
                    #69
                    But, of course. I believe you. Sure I do. No problem. I'm good with this. Sure.
                      #70
                      ............and after those words the rabbit decapitated the guy
                        • 2642
                        #71
                        It'll be 3d printing next thing. Dave will have an embolism!
                          • 13997
                          #72
                          Too late, Andy: I already spewed my venom on that subject at another forum. Needless to say, I became persona non grata over there in minutes.
                          The Horrible
                            Heheheheheheeeeeee..... its so nice to be soooooooo far away; so far away, so far awayeeeee.......
                              #74
                              The business end......I nailed the shape me think.
Name:	Bow Upper (1).jpg
Name:	Bow Upper (3).jpg
Name:	Bow Upper (4).jpg
Name:	Bow Upper (2).jpg
                              Comparison with my AKAULA master....that VICTOR is so much more organic in shape I just love it.
Name:	Bow Upper (5).jpg
                              Grtz,
                              Bart
                                Beautiful is not a good enough word! Yes, you did nail it.
