New 1/72 Golf II kit
  • 598602G
    • Jan 2017
    • 518
    #31
    USS Abraham Lincoln SSB.
    • 598602G
      • Jan 2017
      • 518
      #32
      Half the flood holes on the sail are filed out. Give you an idea on how many flood holes are in a Golf II sail. All the flood holes are molded into the sail. That's what I call a diesel boat. DBF
      • george
        • Dec 2010
        • 731
        #33
        Hi T|im
        As usual your work is incredible! The detail work included by you can`t compare. Keep up the Good Work and Thanks for posting here.
        George
        • 598602G
          • Jan 2017
          • 518
          #34
          Is that you canuck George?
            Your work is incredible! You've Peaked my Interest. If you are looking for ideas about what to build, How about a "MIKE" class in 1/72? If that doesn't tickle your Fancy..... how about a USS Triton also in 1/72?
              Go for something like a WWII Japanese sub in 1/72 - not many of those that are accurate and available.
              • george
                • Dec 2010
                • 731
                #37
                Ya Tim
                That`s me from COLD Canada eh!
                George
                • 598602G
                  • Jan 2017
                  • 518
                  #38
                  Thanks for comments guys. I had to pick a subject that had to outdo my Alfa, Charlie I and the Delta III. I think the Golf II was the best subject to do that. I served on boat during the cold war so I like doing those types of boats. Your boat suggestions are cool. I should be moving back to Dallas in the spring or summer so I need to finish up the Golf soon. I have a 1/72 Thresher/Permit in the wings to build in the future. My lines on a boat after the Golf would be HEN boats. Hotel/Echo/November.
                  • 598602G
                    • Jan 2017
                    • 518
                    #39
                    Hey George I heard Trump is going to deport are illegals to Canada eh. That's what I heard your buddy Anderson Cooper say on CNN. If CNN said it it must be true eh? Just kidding. When are the Hollywood elite going to move next door to you? Ha ha
                    • firma555
                      • Feb 2017
                      • 91
                      #40
                      Project 629 submarines (Golf I,… .Golf V) were the remade project 641 boats.
                      In them, for installation of the R-13 rockets, (surface start - Golf I), and the R-21 rockets (underwater start - Golf II) increased the lower part of the case of the boat and height of the cabin.
                      Contours of the case of the project 629 corresponded to project 641 case contours.
                      On your model case contours wrong (especially its nasal part).
                      Likely you were guided by the provided drawing. This technical documentation can't be used for construction of model, unless that the model was built by the school student.
                      I give below the theoretical drawing of the project 641 and my working drawing according to which I made the boat
                      • 598602G
                        • Jan 2017
                        • 518
                        #41
                        Thanks for the info. I have those same drawings as well as 40+ drawings for the Charlie I. The problems I have run into in making Russian boats is no two are the same. Like the Charlie drawings I got from Russia no two are the same. You can look at photos and no two are the same. Take for instance the Charlie I. Russians mad a early and a late version Charlie I. Basically you have to take the info that is published and see what is consistent. Same with my Golf hull. What you is what is getting molded.
                        • 598602G
                          • Jan 2017
                          • 518
                          #42
                          Perfect example of what I am talking about. 2 different drawings of a Golf II sail. Which one is right and which one is wrong?
                            #43
                            I can help you out here, your SAIL pictures are NOT from the same projects/class
                            The left one is from a GOLF II
                            Project 629A,
                            The right one is from a GOLF I
                            Project 629
                            To be complete, below are the variants on the same, but the difference can be easily noted, except the 629B she is a 629 and 629A lookalike.
                            You can tell the difference between the 629, 629A and 629B as you look to the missile hatches.
                            So if you are making the 629A GOLF II make the sail as the left picture and you will be alright.
                            Project 629B
                            Project 601
                            Project 605
                            Project 619
                            Project 629R
                            Grtz,
                            Bart
Name:	2017-02-03 22_22_59-Ballistic missile submarines - Project 629.jpg
                            • 598602G
                              • Jan 2017
                              • 518
                              #44
                              The one I am doing is on the left Golf II. Here are the pics of the other side of the sail done. Shown is the resin cast mast shroud and navigation lights. Those are in the kit. Just started the hand rails.
                              • 598602G
                                • Jan 2017
                                • 518
                                #45
                                Bottom had railing done. Tomorrow bridge railing and mast shroud railing
