USS SARGO (SSN 583) STATIC MODEL 1/96 Scale
    • 981
    I figured out a way to make the Becker Rudder simply. I sit on sofa at end of day and think how to in my little head among you giants. Tom Anderson is printing the 1/48 hull as I write this. He is using his Bambu Lab A1 large printer. Tom will print two sets of 1/48 rudders. I will have the default Rudders and a second pair printed to rebuild withe Becker flap. It will be then easy to interchange and see the r turning performance firsthand. If I am wrong and my idea doesn't work, I still have the default backups. The upper and lower rudder are identical, just one inverted.
    Click image for larger version  Name:	redesign.jpg Views:	0 Size:	18.3 KB ID:	198599
    Click image for larger version  Name:	Sargo 48 build bottom sections.jpg Views:	0 Size:	49.2 KB ID:	198600
Name:	roy bigge rboat.jpg
      • 981
      Tom Anderson is cranking it out. He is using both machines (show off). Shows second set of rudders for my Becker rudder experiment.
      Updated printing all done. sketching out the bow planes. I know I know that it is supoosed to be drawn on a coffee shop napkin, but didn't have any..lol
      Click image for larger version  Name:	bow plames.jpg Views:	0 Size:	64.0 KB ID:	198682
      Click image for larger version  Name:	Sargo 48 K.jpg Views:	0 Size:	41.9 KB ID:	198683
      Click image for larger version  Name:	Sargo 48 L.jpg Views:	0 Size:	39.5 KB ID:	198684
      Click image for larger version  Name:	Sargo 48 j.jpg Views:	0 Size:	47.8 KB ID:	198685
        • 981
        Re-Designed new Sargo (skate class bow planes. (More rectangular). completed. Randy Sanders redesigned for me after I asked. Thanks. Propellers from Keith Bender arriving in a few hours.
        Click image for larger version  Name:	new bow planes.jpg Views:	0 Size:	44.8 KB ID:	198719
Name:	new BP 3.jpg
          • 981
          Props arrived today.
          Click image for larger version  Name:	KB Sargo Props.jpg Views:	0 Size:	45.0 KB ID:	198724
Name:	sargo 48 prop side.jpg
          • wlambing
            • Nov 2020
            • 402
            Keith does some nice work!
            The outboard corners of the planes should be radiused. Check the Booklet of General Plans, if you have it. I'll look in my research stuff, too.
              • 981
              Thank you. I know, I left a little long till I make the retract system and test for fit first. Note how the tip shape from above is more a radius.
              That's why I'll wait till it's that time. Easier to take off than to add on.
              Isn't the mine cable guard interesting? Mechanically nice they would be available, but if mines got that close, aren't they in a heap of bull dust already? LOL. Of course, mines were different then too. Did the Skates do any special ops like Ivy Bells too?
              Click image for larger version  Name:	bow planes  plan form.jpg Views:	0 Size:	88.0 KB ID:	198730
              • wlambing
                • Nov 2020
                • 402
                I think that after a while, mine cables became one of those ideas that was just bad to start with! Waiting to do your fit-up later is not a bad idea! I don't know if the Skates got too involved in the special operations world, but I think I recall a story of one getting pummeled in the Sea of Oshkosh. Mighta been a different ship, though. I am getting older!
                  • 14014
                  ... and a boat Diver's nightmare. Thank God my boats never bothered with them.
                  • CC Clarke
                    • Aug 2020
                    • 320
                    I'm a big fan of mine cables, having heard a moored mine chain dragging down the side of our ship in Indian Country. I was on the OP you mentioned in '81 (earned every grey hair I had at the tender age of 24). The S-girls did some good recon Spec Ops but weren't configured for what we were doing. No such place as Oshkosh --unless you're into airplanes.
                    • wlambing
                      • Nov 2020
                      • 402
                      a) I don't speak Russian, b) I don't carry a globe with me. The water where Vladivostok is. Near the Kamchatka Peninsula.
                        • 981
                        Thanks, CC Clarke, a very sufficient enough answer for me. The S boats? Interesting slang term for the class. They were smaller than other SSNs, so it seemed logical. Smaller subs seem to b get such work. But the USS Jimmy Carter size seems to sink my submarine size theory. Just were to put everything inside, special electronics and space for a few 'spook' passengers, separating them with a special workspace separate from the crew glimpsing at them only in in e crew's mess. Must have been interesting.
                        When the S boats were not carrying Navy meteorologists to the North pole or photographing polar bears, substituting meteorologist for spooks for a different trip, not North, but 'North by Northwest'. Glad the Skates somewhere someway have such a history operationally, if a very secret one of course.
                        I knew one spook, was a former medical ER doctor and also spoke fluent Chinese. who was sick and tired of pronouncing dead kids in ER's from multiple gunshot wounds. And as usual as you expect contrary to the stupid movies he never stood out, he blended into any crowd easily. I only knew of him because this dumb modeler was lucky enough to run RC subs with him together long ago. He's passed away now, & his name in memory only dies with me. As F Gump, would say, "that's all I want to talk about that."
                          • 981
                          Completed David Merriman / Louis Perez / and me (center bushings and center shaft gear) Sargo 1/48 models shaft splitter gear box.
                          I think I will use the existing 4 bolts to attach to future bulkhead in free flood area after of the e Dive module.
                          Dave? What should I use inside the gear box for lubrication?
                          Next will be the Bow planes retract mechanism. I am going to sound stupid, but I need to know. I will use a small traxxas watertight (resistant) servo for operating to operate the up and down when extended.
                          Do I use same or a different special servo for the retracts? (like Landing gear retracts) . Or same servo and program into the transmitter? I am suspicious of digital transmitters. Everyone I know says they can't figure digital radios out, so anything analog is preferred so I sleep better at night.
                          Click image for larger version  Name:	shaft splitter 3.jpg Views:	0 Size:	41.3 KB ID:	198755 Click image for larger version  Name:	shaft splitter 4.jpg Views:	0 Size:	40.5 KB ID:	198756
                          Click image for larger version  Name:	shaft splitter 2.jpg Views:	0 Size:	44.6 KB ID:	198753 Click image for larger version  Name:	shaft splitter 1.jpg Views:	0 Size:	45.4 KB ID:	198754
                          • BoatBuilderTexas
                            • Nov 2026
                            • 6
                            That shaft splitter gearbox came out really well, Albacore 569. Retracting bow planes on a 1/48 Sargo is an ambitious next step, looking forward to seeing how you work out the mechanism.
                              • Oct 2017
                              • 1121
                              Is this gui a KI Bot?
                                I do not know. He said nice things about me, who am I to complain LOL
