Why are Ships often painted Red below the Waterline?
  • biggsgolf
    • Jan 2020
    • 1036
  • CC Clarke
    • Aug 2020
    • 320
    I worked in the Sonar shop at Trident Refit Facility Bangor for ten years after I got out of the Navy, The hydrophone fairings were painted with Organotin to prevent fouling and it was so toxic we had to wear gloves when removing/installing them. Washington state was one of the first to outlaw it.
    The Red Lead used below the waterline was also changed to some other less-toxic coating. Each Trident was drydocked for a refit every eighteen months when the entire hull would be hydro-blasted, then sand-blasted and re-painted.
    CCC
    • biggsgolf
      • Jan 2020
      • 1036
      Interesting! Thanks
          • 1120
          Growler ( unsure, greyback ir growler's still on display?) as a target ship.
            USS Grayback (SSG-574) departing Subic Naval Base. Painted orange as a target ship. Sunk April 13, 1986.
              • 1120
              Ah yes, ill try to memorize that! Thank you!
