Tool time.
    • 12320
    Are there any 'devices' (angle-keeper, fail-safe, depth-keeper, servo reverser, etc.) between the servo lead and receiver?
    • Davidh
      • Nov 2010
      • 719
      Hi David,
      No nothing. The pinch valve servo runs straight to the receiver. It is cramped inside the ZB cylinder and there's cables everywhere. I put a small toroid around the servo leads I don't know if this is helping. I am considering replacing the servo with a digital one..
      thanks
      David H
        • 12320
        Originally posted by Davidh
        Hi David,
        thanks
        David H
        Someone already suggested that your receiver is maybe sending out-of-place fail-safe commands. Get the documentation on that receiver and see if you can turn off any fail-safe features it may have. Or, replace the receiver and see what happens.
        A full 90-degree 'glitch' ain't a glitch -- something is commanding that. I think your receiver has gone evil on you, pal.
        • george
          • Dec 2010
          • 727
          Is there a brand name 75mhz FM receiver better / more reliable than others? From your Wast Experience HWSNBN ?
            • 12320
            Futaba, Sombra, WFly Polk's are preferred.
ID:	159754Click image for larger version
            I've had so-so success with these. A recent use of one of these was glitchy.
            Carona is another favorite, because of the synthetic crystal.
            • george
              • Dec 2010
              • 727
              Those I guess can still be found in the 75Mhz FM range OR do they have to be converted by a service department?
                • 12320
                Only through after-market sources (rummage sales, estate sales, eBay, swap-meets, club contacts, etc.).
                • Sam Victory
                  • Sep 2021
                  • 391
                  Corona receivers and Henge receivers are also great, with good interference immunity (dual conversion) . The most important thing is that they do not need crystals and can automatically search the frequency from the transmitter (for example, a 40mhz receiver can automatically match 40.67mhz or 40.35mhz or 40.78mhz etc.) The Henge receiver is very compatible and can match JR, WFLY, Futaba transmitters. Of course, both receivers can be set the “Failsafe” device.
                  V
                  Click image for larger version  Name:	coronarp8d140mhz8chreceiver01-01.jpg Views:	0 Size:	24.0 KB ID:	159791Click image for larger version  Name:	2008930185939552.jpg Views:	0 Size:	9.9 KB ID:	159790
                  • george
                    • Dec 2010
                    • 727
                    The Corona synthesized receivers will work with Futaba 75Mhz FM Dual Conversion TX crystals?
                    • Sam Victory
                      • Sep 2021
                      • 391
                      According to this pic, it seems OK.
                      V
                      • george
                        • Dec 2010
                        • 727
                        Thanks Sam Victory, Now ALL I have to do is find one or two. ebay search has been activated, is there an exact corona synthesized model number to look for?
                        I also wanted to ask anyone about the two corona receivers above, I googled both numbers and both ONLY list freq, upto 72mhz. How are they able to work where 75mhz is the legal freq. for surface and water use?
                        • Sam Victory
                          • Sep 2021
                          • 391
                          Well, I do know that 75mhz is the only legel freq in Northern America. 72 mhz works well for rc submarines , but it seems unlawful if you use 72mhz for surface running as 72mhz is used for the aircrafts. Henge "RP82L" 8CH receiver is the crystal-free type , working pretty well for the rc models. You should notice that there are just a few stocks there.
                          Henge receiver - Buy Henge receiver with free shipping on AliExpress
                          V
                          • vital.spark
                            • May 2010
                            • 276
                            I just ordered 2 CORONA RP81D 72mhz receivers for Ali. Just click on Sam's Henge receiver - Buy Henge receiver with free shipping on AliExpress and go to CORONA. They have over 40 left in stock and also have 40mhz available. I have used these in 3 of my Subs and they work like a champ! They are duel conversion and fully synthesized. 72mhz is legal here in Hong Kong and also New Zealand where I also operate.,
                            • Sam Victory
                              • Sep 2021
                              • 391
                              Bingo!
                              V
                              CORONA RP8D1 40Mhz 72MHz 8CH dual conversion synthesized receiver for 41M 72M FUTABA ESKY JR Wlfy Transmitter(NOT need crystal)|Parts & Accessories| - AliExpress
                                • 2759
                                Would the Henge Rx work with an old JR propo Max 6 radio? Click image for larger version
