microviper 10 esc stutter forward only
  • H2Ohaze
    • 117
    #46
    Any news on what I sent in?
      • 13937
      #47
      Still recovering from the flu .... this is the worst I've had in years. Should have your repaired motor-bulkhead out by Monday. Very sorry about the delay.
        • 2615
        #48
        Sounds like you need a holiday, Dave. Have a word with the boss.
        • H2Ohaze
          • 117
          #49
          Any word on motors or whatever is problem?
          • H2Ohaze
            • 117
            #50
            Hello...is there a problem? Haven't heard anything since Jan 4th...
              • 13937
              #51
              I know! I'm back in the shop now. Should have this fixed and out of here by Monday. So sorry for the terribly long delay with this fix.
              • H2Ohaze
                • 117
                #52
                No apologies needed.
                Better to take the time to understand and solidly resolve RC stuff, than to rush-rush the job, be it a sub, sailboat, truck, heli, etc. Just wanted to make sure you didn't forget me. :)
                Carry on...
                • H2Ohaze
                  • 117
                  #53
                  Any progress on the problem?
                    Would you like a foot or two of lead sheet foil to wrap around things? It's sticky one side, so you could plaster it all over the place.
                      • 13937
                      #55
                      I've got this, Mike -- a long overdue repair for a good customer. I'm replacing the entire motor bulkhead over the weekend. I've found no other way to get rid of the interference. I'll post-mortem the motors and see what went prong in one of them.
                      • H2Ohaze
                        • 117
                        #56
                        Something wrong with a motor then? I was a little worried when I noticed the starboard motor turning slower.
                        Did Satlite ever get his issues straightened out?
                        Thanks for all your help on this, Dave.
                          • 13937
                          #57
                          I've got a box full of just assembled and tested 2" SD motor-bulkheads. I'm going to hook one of these up to your device tray see what we get. If no stuttering, then that's the bulkhead you'll get and I start digging into the motor(s) to find crap shorting between case and armature. Things will be resolved today and I'll have a report off to you tonight or tomorrow, followed by shipment of the repaired unit. And thank you for putting up with this long delayed work.Click image for larger version
ID:	76027That's your unit in the cardboard box at the upper, left.
                          • H2Ohaze
                            • 117
                            #58
                            And whatever it is making the ADF2 waggle the blow servo...
                            Thanks for all the time you've spent.
                            Are you going to be able to glue the 180 degree turn resin attachment to the LPB ports? This was also something I asked if you could do, since I didn't think I could glue it and still miss the rudder/ planes seals. I mentioned it in my letter that came with the tray, but I realize it's been awhile now, and it may have been put aside. If you don't have time, that's fine, I'll just need the fitting back...
                              • 13937
                              #59
                              No problem. Thanks for the reminder.
                                • 13937
                                #60
                                Bad news: It does not appear to be one or both motors. I separated them, no change. I replaced the motors by installing a new motor bulkhead, no change. I'm going to stick with the new motors and easter-egg all devices till I find this damned cause of the chattering! I feel like Cal Meachem trying to assemble an Interoceter without the instruction booklet! Click image for larger version
ID:	76050Click image for larger version
ID:	76051Click image for larger version
