21FT Thompson
  • Bob Gato
    • 888
    21FT Thompson
    Pop's second boat...A Rare 21 ft Thompson lap strake boat with a 75hp Johnson Seahorse motor...Bluefish, codfish, tuna, fluke, blackfish and treading clams at Squaw Island. Easy to beach, easy to drive, easy on gas- I attempted to build one only there are no plans and only a few 66 year old slide pictures. Click image for larger version
ID:	197646 Click image for larger version
ID:	197647 Click image for larger version
ID:	197648 Click image for larger version
  • Bob Gato
    • 888
    Since there are no real bulkheads to stiffen the hull (and nowhere to hide the RC equipment) everything will be visible inside and out -
    I decided on using a fiberglass plank in place of the 1st plywood garboard plank that Thompson used to keep the hull ridged. The ribs are CA tack glued to the Masonite formers down in the datum area and notched into the building board for easy removal after planking.
ID:	197665 Click image for larger version
ID:	197666 Click image for larger version
    • Bob Gato
      • 888
      I am using spiled basswood planks epoxied to each other and onto basswood ammonia bent ribs -very similar to the 1:1 method.
      Surprisingly the planked hull was way stronger then I had expected!
ID:	197661 Click image for larger version
ID:	197662 Click image for larger version
      • Bob Gato
        • 888
        The last (Whiskey) Plank has been secured. " Here's to successfully closing up the hull" as customary at this point- a sip of whiskey and a drop down the length of the stem. Thanks to all who cheered me on-one of my most challenging and complex scratch built hulls yet!
          • 13948
          True Craftsmanship on display here. Much to learn from this guy!
          Bob: a 'coffee table' type book chronicling your many wonderful scratch-built projects would be a delight to buy and read. Your work is on the same level as Wingrove, Foran, Crabtree, and Coker. The world needs to see, study, and enjoy your work in that format.
          • Bob Gato
            • 888
            Well, Thanks David...you are too kind... No really you are Too Kind-who are you and what have you done with David?!
            I know there is at least one person interested...I'll keep the pictures coming every few days
            -BG
            • Bob Gato
              • 888
              Since I have no place to hide RC equipment, I decided to make the entire fore deck removable and attach by rare earth magnets-The Battery, receiver, steering servo and the resistors for the LEDs will be up there counterbalancing the outboard motor hanging off the transom. The windshield and glazing are being mocked up-they will be the last to go on permanently (for fear of damage) Note: the windscreens will be operational. The power for the lights will transfer via self aligning magnetic "pogo pins" The removable companionway bulkhead is being fabricated ...and the aft bench seat is where I will hide the Python ESC
              -BG
ID:	197723Click image for larger version
Name:	P5200087 - Copy.jpg
ID:	197717Click image for larger version
ID:	197718Click image for larger version
ID:	197719 ​​ Click image for larger version
ID:	197720Click image for larger version
ID:	197721Click image for larger version
                • 1639
                Do they make the outboards for it, for RC? Very sweet build.
                • Bob Gato
                  • 888
                  Thanks man...
                  They do make outboards for it-but as you will see later on in the build, real outboards with geared lower units are too heavy and larger than scale. I chose a mini outboard by TFL that has a cable drive but that means I had to sacrifice reverse (can't reverse a cable drive or it will unwind and jam) These units have a 3000Kv -way too powerful with no mid range-I swapped out the 3000Kv for a 1200Kv and went for a CNC aluminum 2 blade prop-she runs GREAT now. I fabricated a replacement cowl to look like a 1960 Johnson 75 and re machined the high speed lower unit to look more like the 4cyl Johnson-Stay Tuned...BG
                  • Bob Gato
                    • 888
                    Well I might as well tell about the motor-It started as a cable driven TFL mini scale outboard as mentioned above...It is a gofast outboard out of the box and I had to tame her down-also the modern looking Merc didn't hack it on the back of a 66year old boat. I made a plug accordingly and molded a new cowl incorporating 1960 points of interest and removed much of the unneeded empty space-beside needing some cosmetic changes, it also needed mechanical work. It now has a 1200Kv B/L motor and a CNC aluminum two blade prop which allows the boat to plane and cruise unaffected while sucking in vent air from under and around the hull. I also fabricated a cavitation (vent air) plate both for looks and corralling that air from above the prop. I also needed a steering horn since I decided to use a Sullivan cable to steer from below the waterline as a result of only having 1/4" space below the deck and above the ribs. the cable runs forward and comes above the water line as it curves up to the steering servo mounted high, just below the fore deck. Also note the carved aluminum lower unit -its not 100% 1960 but it sends the viewer's mind in the right direction. Decals and other markings courtesy Bob Gaito-BG
                    Click image for larger version  Name:	Screenshot (181).png Views:	0 Size:	27.0 KB ID:	197740 Click image for larger version  Name:	P1060031.jpg Views:	0 Size:	63.7 KB ID:	197741Click image for larger version  Name:	P1020003.jpg Views:	0 Size:	42.9 KB ID:	197742​ ​Click image for larger version  Name:	20260821_125918.jpg Views:	0 Size:	57.8 KB ID:	197743Click image for larger version  Name:	20260913_104112.jpg Views:	0 Size:	58.6 KB ID:	197744
