21FT Thompson
  • Bob Gato
    • 898
    21FT Thompson
    Pop's second boat...A Rare 21 ft Thompson lap strake boat with a 75hp Johnson Seahorse motor...Bluefish, codfish, tuna, fluke, blackfish and treading clams at Squaw Island. Easy to beach, easy to drive, easy on gas- I attempted to build one only there are no plans and only a few 66 year old slide pictures. Click image for larger version
ID:	197646 Click image for larger version
ID:	197647 Click image for larger version
ID:	197648 Click image for larger version
  • Bob Gato
    • 898
    Since there are no real bulkheads to stiffen the hull (and nowhere to hide the RC equipment) everything will be visible inside and out -
    I decided on using a fiberglass plank in place of the 1st plywood garboard plank that Thompson used to keep the hull ridged. The ribs are CA tack glued to the Masonite formers down in the datum area and notched into the building board for easy removal after planking.
ID:	197665 Click image for larger version
ID:	197666 Click image for larger version
    • Bob Gato
      • 898
      I am using spiled basswood planks epoxied to each other and onto basswood ammonia bent ribs -very similar to the 1:1 method.
      Surprisingly the planked hull was way stronger then I had expected!
ID:	197661 Click image for larger version
ID:	197662 Click image for larger version
      • Bob Gato
        • 898
        The last (Whiskey) Plank has been secured. " Here's to successfully closing up the hull" as customary at this point- a sip of whiskey and a drop down the length of the stem. Thanks to all who cheered me on-one of my most challenging and complex scratch built hulls yet!
          • 13985
          True Craftsmanship on display here. Much to learn from this guy!
          Bob: a 'coffee table' type book chronicling your many wonderful scratch-built projects would be a delight to buy and read. Your work is on the same level as Wingrove, Foran, Crabtree, and Coker. The world needs to see, study, and enjoy your work in that format.
          • Bob Gato
            • 898
            Well, Thanks David...you are too kind... No really you are Too Kind-who are you and what have you done with David?!
            I know there is at least one person interested...I'll keep the pictures coming every few days
            -BG
            • Bob Gato
              • 898
              Since I have no place to hide RC equipment, I decided to make the entire fore deck removable and attach by rare earth magnets-The Battery, receiver, steering servo and the resistors for the LEDs will be up there counterbalancing the outboard motor hanging off the transom. The windshield and glazing are being mocked up-they will be the last to go on permanently (for fear of damage) Note: the windscreens will be operational. The power for the lights will transfer via self aligning magnetic "pogo pins" The removable companionway bulkhead is being fabricated ...and the aft bench seat is where I will hide the Python ESC
              -BG
ID:	197723Click image for larger version
Name:	P5200087 - Copy.jpg
ID:	197717 ​ Click image for larger version
ID:	197718​ Click image for larger version
ID:	197719 ​​ Click image for larger version
ID:	197720​ Click image for larger version
ID:	197721​ Click image for larger version
                Do they make the outboards for it, for RC? Very sweet build.
                • Bob Gato
                  • 898
                  Thanks man...
                  They do make outboards for it-but as you will see later on in the build, real outboards with geared lower units are too heavy and larger than scale. I chose a mini outboard by TFL that has a cable drive but that means I had to sacrifice reverse (can't reverse a cable drive or it will unwind and jam) These units have a 3000Kv -way too powerful with no mid range-I swapped out the 3000Kv for a 1200Kv and went for a CNC aluminum 2 blade prop-she runs GREAT now. I fabricated a replacement cowl to look like a 1960 Johnson 75 and re machined the high speed lower unit to look more like the 4cyl Johnson-Stay Tuned...BG
                  • Bob Gato
                    • 898
                    Well I might as well tell about the motor-It started as a cable driven TFL mini scale outboard as mentioned above...It is a gofast outboard out of the box and I had to tame her down-also the modern looking Merc didn't hack it on the back of a 66year old boat. I made a plug accordingly and molded a new cowl incorporating 1960 points of interest and removed much of the unneeded empty space-beside needing some cosmetic changes, it also needed mechanical work. It now has a 1200Kv B/L motor and a CNC aluminum two blade prop which allows the boat to plane and cruise unaffected while sucking in vent air from under and around the hull. I also fabricated a cavitation (vent air) plate both for looks and corralling that air from above the prop. I also needed a steering horn since I decided to use a Sullivan cable to steer from below the waterline as a result of only having 1/4" space below the deck and above the ribs. the cable runs forward and comes above the water line as it curves up to the steering servo mounted high, just below the fore deck. Also note the carved aluminum lower unit -its not 100% 1960 but it sends the viewer's mind in the right direction. Decals and other markings courtesy Bob Gaito-BG
                    Click image for larger version  Name:	Screenshot (181).png Views:	0 Size:	27.0 KB ID:	197740 Click image for larger version  Name:	P1060031.jpg Views:	0 Size:	63.7 KB ID:	197741 ​ Click image for larger version  Name:	P1020003.jpg Views:	0 Size:	42.9 KB ID:	197742​ ​Click image for larger version  Name:	20260821_125918.jpg Views:	0 Size:	57.8 KB ID:	197743​ Click image for larger version  Name:	20260913_104112.jpg Views:	0 Size:	58.6 KB ID:	197744
                    • Bob Gato
                      • 898
                      "Bling" that thing of interest that brings attention to something that would not normally have interest...(earrings on a pig)
                      I fabricated several items to do just that. The detailed cockpit with period gages -a scale steering wheel(very rare) that was on the 1:1. Johnson shift master control with a Bob Gato repro decal, brass cleats, showing two of the six on board...Bow nav light made from two masthead lights (Harbor Models) which I cut in half to use the lenses in a home made brass and JB weld Perko housing. The Thompson aft quarter badging (purchased from Callie Graphics) Just send her your drawing and she can make almost anything (these are 0.8" x 0.2" with two color and a white perimeter border) ...Replica deck chairs that were on the original 1:1- the tow eyes made from silver soldered brass 2/56 screws.
                      I also needed to replicate the US Coast Guard Auxiliary Courtesy Inspection sticker that was in the corner of the side window of my Dad's boat every year-I could only find an image of one from 1966 so I photo shopped it into a 1961 sticker (can be seen in the cockpit picture below).
                      -BG
                      Click image for larger version  Name:	20260823_062007.jpg Views:	0 Size:	52.1 KB ID:	197777 Click image for larger version  Name:	P5150063.jpg Views:	0 Size:	40.8 KB ID:	197778 ​ Click image for larger version
                      ​ Click image for larger version  Name:	P4020038.jpg Views:	0 Size:	31.7 KB ID:	197779​ Click image for larger version  Name:	P4050043.jpg Views:	0 Size:	34.7 KB ID:	197780
                      ​ Click image for larger version  Name:	P5100046.jpg Views:	0 Size:	33.8 KB ID:	197781​ Click image for larger version  Name:	P1030005.jpg Views:	0 Size:	58.9 KB ID:	197782
                      Click image for larger version  Name:	1966.jpg Views:	0 Size:	9.8 KB ID:	197773Click image for larger version  Name:	1961.jpg Views:	0 Size:	9.5 KB ID:	197774
                      • Bob Gato
                        • 898
                        I needed a MFG plate for the Tempo fuel tank that I am using to hide the ESC under the aft bench seat-but it showed that it was made in 1967 so I photo shopped a 1959 date instead...then there is the brazed assembly to be the anti-cavitation plate and my steering horn that is bolted to the lower unit of the modified outboard...The ships wheel (readers digest version-3 steps) and also more bling...and out of sequence is the view of the magnetically held Tempo fuel tank hiding the ESC under the hinged aft seat (yea I know its not sitting straight- the two screws that hold it are not in place...its the only picture I had
                        BTW that QTY gage is 1/8" diameter -BG
                        iClick image for larger version  Name:	1959.jpg Views:	0 Size:	58.1 KB ID:	197785 Click image for larger version  Name:	20260819_105301.jpg Views:	0 Size:	75.0 KB ID:	197786 ​​​ Click image for larger version  Name:	P4210007.jpg Views:	0 Size:	43.5 KB ID:	197787 ​​ Click image for larger version  Name:	P4240017.jpg Views:	0 Size:	27.4 KB ID:	197788​​ ​ ​​ Click image for larger version  Name:	P5190076.jpg Views:	0 Size:	34.9 KB ID:	197791​ Click image for larger version  Name:	20260819_105254.jpg Views:	0 Size:	75.9 KB ID:	197792
                        Click image for larger version  Name:	P4240020.jpg Views:	0 Size:	48.5 KB ID:	197789 Click image for larger version  Name:	P5020032.jpg Views:	0 Size:	45.8 KB ID:	197790 ​
                          • 3758
                          Love the attention to details as well as the detail you put into your boats. Excellent!
                          • Bob Gato
                            • 898
                            Thanks Tom, very nice of you to say-BG
                            • Bob Gato
                              • 898
                              As some of you might remember, I'm the type of guy that does a lot of experimentation, and I was never happy with the chrome paint that rust-olium sells for use on my models. Even though the initial finish is a gleaming chrome plate look. It does not take very much effort to turn that shiny Chrome into a dull gray. Just touch it with a little solvent of any kind or clear coat over the top or even just the oil from your fingers will change it to Gray..
                              To protect it, I have called rostolium, and their answer to me is that it just is what it is. And there is no clear coat that will work.
                              I have since come to the conclusion that if we could only coat it with something that doesn't have a solvent in it, that would also be waterproof once dry it would allow a top coat that did have solvent in it..
                              My answer was a three coat process. The first coat is, of course, the rustolium bright chrome... Second coat comes after a two day, wait... I use water base polychrylic clear. After the polychrylic is dry...The third coat is to now cover it with rustolium crystal clear enamel. The polycrylic protects the original coat from the enamel solvents and the enamel makes the polycrylic waterproof.-BG
