3D Printed Utility Boat
    • 1795
    This will be my build blog of a 3D printed RC Utility Boat!
Name:	Utility Boat 1.jpg
    • 1795
    This boat when complete, will be a total 21.5" long with a beam of 5.25".
Name:	Utility Boat 2.jpg
    I will be printing this boat using a Dremel DigiLAB 3D40. I will be using Dremel PLA White filament, and printed at 100% infill. The photo shows the bow section of the boat (5 total hull sections) and it will take a total of 24.5 hours to complete the bow!
      • 2753
      Nice. Kinda reminds me of this
        • 2753
          • 1795
          Well, I have 32 hours of 3D printing on the Utility Boat and I am already missing building submarines!
Name:	Utility Hull Building 1.jpg
ID:	156407Click image for larger version
Name:	Utility Boat Hull build 2.jpg
          I hope you "Bubble Heads" won't give up on me! Just needed a break!
            • 803
            Enjoy the diversion and keep posting Rob.
            • type7
              • 153
              Neat little boat! Where did you get the files?
                • 1795
                Hi Bob,
                I got the files from Thingiverse, It's called the Utility Boat.
                  • 1795
                  Typical situation with joining 3D printed boat sections together. You always have a little sanding to do to line up the joints.
Name:	Utility Boat joints 1.jpg
ID:	156437Click image for larger version
Name:	Utility Boat joints 2.jpg
                  A good flat sanding board, and some 100 GRT paper will bring things into a good tight fit!
                  • Monahan Steam Models
                    • 755
                    Looks good Rob!
                      • 1795
                      Looks good Rob!
                      Thanks Nick,
                      It is turning out to be a very strong hull building at 100% infill, but that will give me a good base to really get a smooth surface for applying my final finishing. I will apply glass and resin to all the interior joints, and then apply a coat of resin to the entire surface interior for keeping out any possible water penetration.
                        • 2753
                        So it's the same as the boat in the video.
                        The utility 3D printed ship is here! this is a combination of everything I've been looking for in a mid sized to large ship. Featuring twin screws and a deep draft its definitely designed to move some water and pull a canoe or something across a lake! The thick walls allow for plenty of abuse and hopefully survivability in some of the toughest seas. Go ahead and make one! If you stumbled upon this thing be sure to check out the video here:https://www.youtube.com/watch?v=QaIjdgTiP0o
                          • 1795
                          https://www.thingiverse.com/thing:2192118
                          Very similar, but not the same size. Mine is a smaller version.
                            • 1795
                            The hull sections on the Utility Boat are complete!
Name:	Finished Hull 1.jpg
ID:	156479Click image for larger version
Name:	Finished Hull 2.jpg
                            All five sections to the hull came together quite nicely. Very little fill work will be required. Next comes bonding the hull sections together using a quality medium density CA.
                            "Firemen can stand the heat'
                              • 2753
                              Rob can take a picture of the hull with you holding it so I can get a reference to it's size.
