3D Printed Utility Boat
    This will be my build blog of a 3D printed RC Utility Boat!
Name:	Utility Boat 1.jpg
    This boat when complete, will be a total 21.5" long with a beam of 5.25".
Name:	Utility Boat 2.jpg
    I will be printing this boat using a Dremel DigiLAB 3D40. I will be using Dremel PLA White filament, and printed at 100% infill. The photo shows the bow section of the boat (5 total hull sections) and it will take a total of 24.5 hours to complete the bow!
      Nice. Kinda reminds me of this
          Well, I have 32 hours of 3D printing on the Utility Boat and I am already missing building submarines!
Name:	Utility Hull Building 1.jpg
ID:	156407Click image for larger version
Name:	Utility Boat Hull build 2.jpg
          I hope you "Bubble Heads" won't give up on me! Just needed a break!
          • SubDude
            • 825
            Enjoy the diversion and keep posting Rob.
            • type7
              • 198
              Neat little boat! Where did you get the files?
                Hi Bob,
                I got the files from Thingiverse, It's called the Utility Boat.
                  Typical situation with joining 3D printed boat sections together. You always have a little sanding to do to line up the joints.
Name:	Utility Boat joints 1.jpg
ID:	156437Click image for larger version
Name:	Utility Boat joints 2.jpg
                  A good flat sanding board, and some 100 GRT paper will bring things into a good tight fit!
                  • Monahan Steam Models
                    • 755
                    Looks good Rob!
                      Looks good Rob!
                      Thanks Nick,
                      It is turning out to be a very strong hull building at 100% infill, but that will give me a good base to really get a smooth surface for applying my final finishing. I will apply glass and resin to all the interior joints, and then apply a coat of resin to the entire surface interior for keeping out any possible water penetration.
                        So it's the same as the boat in the video.
                        https://www.thingiverse.com/thing:2192118
                          Very similar, but not the same size. Mine is a smaller version.
                            The hull sections on the Utility Boat are complete!
Name:	Finished Hull 1.jpg
ID:	156479Click image for larger version
Name:	Finished Hull 2.jpg
                            All five sections to the hull came together quite nicely. Very little fill work will be required. Next comes bonding the hull sections together using a quality medium density CA.
                            "Firemen can stand the heat'
                              Rob can take a picture of the hull with you holding it so I can get a reference to it's size.
