Balancing a WTC
    • 3472
    Balancing a WTC
    Just watch Tiver21s latest YT video where he shows his WTC for his 1/72 Kilo. In the video he placed tire weights inside the WTC to impart roll stability. Shouldn't the weights be on the hull?
    • Jan 2020
    • 1025
    Saw that too, not sure what advantage if any?
      • 13632
      Yes. If for no other reason than to get the fixed ballast weights as low in the structure as possible.
        • 3670
        I have seen weights added to a WTC, mostly in VERY old postings. Some would level their WTC, then add weight to a hull for any minor corrections. I would guess the thought process is moving the wtc around to different subs would be simpler, maybe keep hull weight down too. I do not know it does not work for my brain.
          • 1981
          Keeping the weight in the cylinder reduces the effectiveness of them. The further the distance between your center of buoyancy and center of mass, the more stable the boat.
            • 1568
            You have to turn the volume off to watch the damn thing. Obnoxious music in videos are the most annoying thing in the world. Besides, who puts their weights in the WTC? Never seen, heard, or even thought about it.
