Trim Issues
    • Jan 2020
    • 1031
    Trim Issues
    1:96 Scale Skipjack, surface trim good, submerged trim good, however, as I turn or slow down the bow rises causing the sail to to surface, and the boat is no longer level, (bow higher then stern). Using the R&R cylinder and 2.4 Ghz antenna inside a mast above water in submerged trim. Any ideas?
    • Jan 2020
    • 1031
    (Fixed Sail Planes, operational Dive Planes)
      • 2626
      If you're saying that the static trim changes, then there may be some trapped air in the hull. Dynamic changes are another matter, and it's common for a boat to lift its snout on a turn.
        • 13947
        Yeah. What Andy said. You're chasing an internal bubble. Do a better job of venting the hull back aft. Opening up the ballast tank main vent valve positions of the kit is an ideal 'scale' method of ventilating the hull back there.
          • Jan 2020
          • 1031
          Thanks guys! Will do for next run
            Click image for larger version  Name:	134863A5-D5FD-4AE6-A117-1A4D37DA212D.jpg Views:	0 Size:	94.8 KB ID:	180454 This bulkhead may be trapping air.
            https://forum.rc-sub.com/forum/build...tilus-drydocks
              • Jan 2020
              • 1031
              Agreed, I previously tried to vent it better, will be looking at it again.
              • Thorbrandr
                • Mar 2022
                • 153
                Taking care of trapped air is always good.
                As stated above, boats will tend to rise in turns.
                My R10, with the raised bulbous bow, and low mounted rudders does this, and even my 212 with the X tail.
