Field Repair kit/ Toolbox
    • 3512
    What basic tools or items do you carry everytime you run your boats?
  • Farlan
    • Jun 2016
    • 2
    I carry the usual tools in a small box. Also, extra weights, flotation foam, etc.
      • 13697
      Typical tool, consumable, and test gear at the operating site.
        • 3512
        Those extra long hemostats do come in handy for those hard to reach places. Look for Mixter Haemostatic forceps, their tip are bent. Click image for larger version
        No baking soda and super glue?
          • 13697
          Most of the consumables are in the grey and red field-box.
            • 743
            Could you please give a list of 'the usual' tools please? Hemostats are critical I agree.
            • QuarterMaster
              • Sep 2015
              • 1237
              I'm the first to admit I "march to the tune of a different drum". I don't look at this passion of mine as a way to save money. As my primary source of recreation and skill growth I spare no expense. I also don't drink, or spend cash at strip joints so I can budget it. Hey, whatever floats your boat, in my case that's Co2
              I break it down into two requirements:
              1-Local, every day runs.
              2-Long distance Events (Fun Runs and Regattas.) I live for these events and don't wish to be unprepared after driving 1200 miles.
              I purchased the Milwaukee Packout System after seeing Vaughn Schmitt use his. I had to have it.
              Works as a Field Kit, Regatta kit, Boat Launcher and Hauler
              I will usually just need that top section when I run locally.
              The bottom is for major events where I bring everything but the kitchen sink.
ID:	172450Click image for larger version
              As you can see it packs neatly in my F-150!
              NOW, your needs will be different, David's (HWMNBN) needs are different, Bob's needs are different, EVERYONE'S NEEDS ARE DIFFERENT!
              Choose accordingly.
              You can go with a very inexpensive tackle box as most do and works quite well, that does not fit MY needs.
              So to all the eye rollers regarding cost, this is not a requirement, just an indication of the possibilies.
              Your original question regarded tools.
              I keep a check list on the back of my laminated "Rig for Dive Checklist"
              This is the minimum I bring stepping out of the home.
              For the record, this checklist,. and the aforementioned "Rig for Dive Checklist" was derived from all of David's (HWMNBN) various Kit Instructions and posts.
              Here is the list in text form
              FIELD KIT INVENTORY
              1. TOOLS:
                1. SMALL SCREWDRIVERS
                2. ALLEN WRENCHES
                3. CHARGING HOSE
                4. TWEEZERS
                5. X-ACTO
                6. NEEDLE NOSE PLIERS
                7. “T”-PINS
                8. MULTI-METER
                9. SPONGE
                10. TIRE VALVE CAP
                11. SUNGLASSES
                12. HAT
              1. CONSUMABLES:
                1. CA (THICK/THIN)
                2. CA ACCELERATOR
                3. CA FILLER
                4. “CORROSION X” OIL
                5. GREASE
                6. WIPES
                7. RUBBER BANDS
                8. ELECTRICIANS TAPE
                9. CLOSED CELL FOAM
                10. LEAD WEIGHTS
                11. “PROPEL”
                12. SUNBLOCK
              v/r "Sub" Ed
              • Fishb0y
                • Jul 2023
                • 144
                or spend cash at strip clubs
                Welp… there goes half the items I can afford for my kit.
                • QuarterMaster
                  • Sep 2015
                  • 1237
                  This should help.....
                  v/r "Sub" Ed
                    • 3512
                    FIELD KIT INVENTORY
                    1. TOOLS:
                      2. ALLEN WRENCHES
                      3. CHARGING HOSE
                      4. TWEEZERS
                      5. X-ACTO
                      7. “T”-PINS
                      8. MULTI-METER
                      9. SPONGE
                      10. TIRE VALVE CAP
                      11. SUNGLASSES
                      12. HAT
                    1. CONSUMABLES:
                      1. CA (THICK/THIN)
                      2. CA ACCELERATOR
                      3. CA FILLER
                      5. GREASE
                      6. WIPES
                      7. RUBBER BANDS
                      9. CLOSED CELL FOAM
                      10. LEAD WEIGHTS
                      11. “PROPEL”
                      12. SUNBLOCK
                    How about Zipties or wire?
                    • Fishb0y
                      • Jul 2023
                      • 144
                      And there goes the other half!
                        • 1572
                        Merriman’s table looks like something out of a mobile field hospital.
                        • wlambing
                          • Nov 2020
                          • 386
                          The box itself does not need to be very fancy. I've been using my Plano plastic pistol range box for about 28 years. Has compartments for the little stuff and plenty of room in the bottom for the larger things, including spare cans of Propel and strips of automotive wheel weights and 1/2"x1/2"x12" closed cell trimming foam. The CA bottles go in the bottom, too. The lid has a locking inner lid that keeps you from dumping stuff when you flip it for opening/closing. Start out with something at reasonable cost and with small hand tools. As time goes on, you'll acquire those things you need here and there.
                          Many of the tools and materials I've collected go unused for 98% of the time. My Submarine Auxiliaryman Fix-the-boat (1:1 scale) tools nowadays only get broken out to fix the lawn tractor! But, I pretty much know where ALL of my tools are, with many of the most used either in or near my rc boat field box.
                          You won't be using zip-ties or wire unless you're gutting and overhauling your boat, and that's best done at home on the workbench. There are too many itty-bitty screws and such to be doing so at the beach. David can do stuff like that, but we mortals usually only cause ourselves more pain and sorrow when we try.
                          Take care,
                          Bill
