Moebius Seaview Fixed Vanes
    • 3466
    HWSNBN, regarding the fixed vanes in the Seaview propulsors, as your fitting kits are hard to acquire these days, I guess a piece of plastic card makes a good alternative but can one just use the movable stern dive planes and set them at a down angle when at neutral to counter the nosedive phenomenon of the Seaview when running? Click image for larger version  Name:	pxjL7F.webp Views:	0 Size:	20.6 KB ID:	172142
    • 13625
    Nope. The 'neutral' position of the stern planes is as you see in the photo. This is their position with the boat at a zero pitch-angle and the stern plane servo centered.
ID:	172146Click image for larger version
Name:	Img0413 - Copy.jpg
    • wlambing
      • Nov 2020
      • 383
      From the pictures it appears that neutral is at a slight rise angle, not down. This will tend to hold her nose up as she proceeds through her mission.
        • 13625
        Correct sir. Needed to counter the shovel-nosed SEAVIEW from plowing down at any significant submerged speed.
          • 3466
          When I said angled down I was referring to the position of the leading edge of the diveplane. I realize now that when we talk about diveplanes position we alway pertain to the trailing edge.
          Looking back at the photo I do see that the trailing edge of the stern plane (red line) is above the horizontal pivot (green line). Click image for larger version  Name:	Seaview stern planes.jpg Views:	0 Size:	54.2 KB ID:	172154
