Beginner question! Sealant!
    • 3513
    #31
ID:	163770Click image for larger version
ID:	163771Click image for larger version
ID:	163772Click image for larger version
      • 3513
      #32
      Click image for larger version  Name:	200 Sovremenny 1.jpg Views:	0 Size:	79.9 KB ID:	163780Click image for larger version  Name:	200 Sovremenny 3.jpg Views:	0 Size:	57.2 KB ID:	163781
        • 3513
        #33
        Last photos shows a pair of 180 motors.
        • GatoGaterDom
          • Jul 2022
          • 14
          #34
          Wow your Sovremmeny came out nice.
          What I did before coming here was remove the old wiring, the old receiver, and added a Flyski receiver with two ESCs. I had proportional control on both throttles before messing something up with the motor. I even managed to connect a servo to the forward 30mm turret. I had kept the stock motors cause at the time they worked.
          The vessel has no rudder, but I am not sure if I want to undertake the challenge of adding a rudder, although it would be a good learning experience. Might think about that….
          What I am currently doing is replacing the motors.
          • GatoGaterDom
            • Jul 2022
            • 14
            #35
            Where do you guys get brass parts for rudder and stuffing boxes, shafts and couplings?
            Dedicated RC ones are quite expensive. Where can I simply get the parts and do the work myself? I have angles grinders, saws and drills.
            Looking forward to my next project of converting an old Tamiya New Jersey I have lying around.
              • 13699
              #36
              "... simply get the parts and do the work myself?".
              Wow!
              Either pay Dumas what they want for finished product. Or spend the big-bucks to properly outfit your man-cave after graduating from the school-of-busted-thumbs-and-stiches.
              Pick one!
              This ain't a hobby one casually gets into without some kind of meaningful investment (time, money, talent, commitment, wife-appeasement, practice, and getting on speaking terms with your tools).
              Machine and Cartridge brass (tube of all shapes, sheet, shim, strip, structural shapes, and round stock of all shapes) available from McMaster-Carr. You handy with drill-press, lathe and mill? If you're serious about 'making your own stuff', then you need the proper tools.
              You game?
              Click image for larger version  Name:	012 (3).JPG Views:	0 Size:	96.2 KB ID:	163789
              Click image for larger version  Name:	DSCN0028.JPG Views:	0 Size:	97.3 KB ID:	163790
              Click image for larger version  Name:	004.JPG Views:	0 Size:	83.0 KB ID:	163791
              Click image for larger version  Name:	IMG_2233.JPG Views:	0 Size:	58.3 KB ID:	163792
              • GatoGaterDom
                • Jul 2022
                • 14
                #37
                Got it.
                Doing this for the fun of the build, much less the finished product so was curious as to what that process would look like. Clearly out of my current capabilities.
                Thanks, Dom.
                  • 13699
                  #38
                  I'm here to teach. Not make you feel good about yourselves (that's your job).
                  The Horrible
