Real life application of SAS
    • 3622
    Can you use the SAS principle in a real life situation?
    That is using air inside the hull to blow the ballast tank.
    Wouldn't it result in negative pressure in the boat?
    • 13842
    The SAS is based on 'real life' low pressure blow of the main ballast tanks. However, in real life, the pump is not started till the main induction valve is opened. And that happened the moment the sail broached the surface. Boats get ear-popping all the time on the snorkel.
      • 3622
      So you can't use the air inside to blow ballast with the induction close. Even if the volume of air inside is larger than the BT?
        • 13842
        You can (on the Trutta we did on occasion), but not recommended.
          • 3622
          105% Click image for larger version
            • 2017
            Goddam...that would pop your ears for sure!
            • wlambing
              • Nov 2020
              • 389
              Helps keep the wax build-up down!! It was always fun doing the diesel engine vacuum shutdown switch tests for maintenance and ORSE!! ;)
                • 13842
                Ouch! Yet another reason to hate the Squadron rat-patrol.
