3D Printing Hollow Bridge
    • Jan 2020
    • 987
    Hi all, when using Cura I cannot figure out how to print my bridge hollow. Cura shows it hollow but prints a 2.3 mm solid bottom and at the top. Inhave tried raising it with supports. I have been placing it level with base at the bottom. Help!
  • CC Clarke
    • Aug 2020
    • 296
    Does the STL have a solid base?
    • DrScoles
      • Jun 2021
      • 7
      Do you have meshmixer? Simple to do a plane cut, or hollow, then plane cut. I am on vacation in Mexico, but if you need help with this, pm me and send file, it would take a few minutes on Monday.
      • CC Clarke
        • Aug 2020
        • 296
        I can review and repair the file now if needed.
        CC
          • Jan 2020
          • 987
          The STL does not have a solid base
            • 1936
            Make sure you are using a raft!
            • RanSan
              • May 2020
              • 61
              What is your setting for Bottom layers in Cura? It should be 0.
              Randy
                • Jan 2020
                • 987
                Thanks guys, I will try using a “raft”. My last attempt is better, using “spiralise Outer Contour” and disabling “Union Overlapping Volumes”. The walls are too thin, lol
                  • Jan 2020
                  • 987
                  Randy
                  Randy, it is 12. What should top layers be? For thicker walls what should I change?
                    • Jan 2020
                    • 987
                      • Jan 2020
                      • 987
                      When using a raft should the Bridge be on the bed or raised above?
                        • 1936
                        [QUOTE=biggsgolf;n151308]When using a raft should the Bridge be on the bed or raised above?[/QU
                        Flat to the bed!
                        • RanSan
                          • May 2020
                          • 61
                          What version of Cura are you using? Not that it matters it is just different than the latest.
                          I use Wall Line Count and Top and Bottom Layers not Thickness. I have a rough idea of the thickness by looking at the Line Width under Quality? Use that to figure out the rest. For example I use 0.4mm Line Width. My walls are 2mm so 2 / 0.4 = 5 wall count. My tops are 3-5 layers and my bottoms are 0-3.
                          Personal perference, I don't use rafting it uses to much material. I like 10 count on brim.
                          Hope that helps.
                          • RanSan
                            • May 2020
                            • 61
                            Oh ya don't use spiralise Outer Contour that will only give you 1 wall.
                              • Jan 2020
                              • 987
                              Great info guys, many thanks. I am using version 3.6.0 as any newer version does not work on my older Macbook.
