Thanks!
Bottom Layers 0
Flat to bed
10 Count Brim
Top Layers 4
Wall Line Count 5
3D Printing Hollow Bridge
Looking at my support settings is there a way to print less material inside the hollow Bridge?4 PhotosLeave a comment:
Great info guys, many thanks. I am using version 3.6.0 as any newer version does not work on my older Macbook.Leave a comment:
Oh ya don't use spiralise Outer Contour that will only give you 1 wall.Leave a comment:
What version of Cura are you using? Not that it matters it is just different than the latest.
I use Wall Line Count and Top and Bottom Layers not Thickness. I have a rough idea of the thickness by looking at the Line Width under Quality? Use that to figure out the rest. For example I use 0.4mm Line Width. My walls are 2mm so 2 / 0.4 = 5 wall count. My tops are 3-5 layers and my bottoms are 0-3.
Personal perference, I don't use rafting it uses to much material. I like 10 count on brim.
Hope that helps.Leave a comment:
[QUOTE=biggsgolf;n151308]When using a raft should the Bridge be on the bed or raised above?[/QU
Flat to the bed!Leave a comment:
When using a raft should the Bridge be on the bed or raised above?Leave a comment:
Thanks guys, I will try using a “raft”. My last attempt is better, using “spiralise Outer Contour” and disabling “Union Overlapping Volumes”. The walls are too thin, lolLeave a comment:
What is your setting for Bottom layers in Cura? It should be 0.
RandyLeave a comment:
