AD2
  • biggsgolf
    • Jan 2020
    • 1028
    AD2
    Can anyone provide instructions on how to reset an AD2? I thought I would merely need to put in setup mode and redoe the settings but I cannot get it to go into setup mode. As it is, it is working but I need to adjust the servo throw endpoints it records.
  • Ken_NJ
    • Sep 2014
    • 1003
    Try contacting Kevin at kevinmc.electronics@gmail.com
      • 2037
      You're going about entering setup mode correctly? Power off cylinder, press setup button on AD2, power on RX, wait for the single, then double green lights and you're in the correct mode...
      • biggsgolf
        • Jan 2020
        • 1028
        hi Bob, yes, but green light does not stay lit
          • 2037
          Well, I'm stumped then. Give Kevin a shout. He'll get back to you almost immediately if past stays true.
          • biggsgolf
            • Jan 2020
            • 1028
            will reach out to him, thanks
            • biggsgolf
              • Jan 2020
              • 1028
              Update:
              AD2 was connected to RX with wrong polarity, still powered on and worked, but could not re program it. Now is corrected.
                • 2037
                Powered up with positive 5v and grounding through the signal wire!? Wow. I’d never have thought…
                • biggsgolf
                  • Jan 2020
                  • 1028
                  Me neither!
