Dual Prop Submarines
  • biggsgolf
    • Jan 2020
    • 1036
    Do the drive shafts spin in opposite directions? Are the propellers both right or left turn, or one of each?
    • 1121
    One right tourning, one left tourning to neutralize the radial spin momentum
    • wlambing
      • Nov 2020
      • 402
      It also depends on what nation's boat you are doing, and the level of accuracy you wish to apply. USN 2-shaft boats turned to outboard. Port screw= counter-clockwise, Stbd screw= clockwise. Soviet's went inboard, opposite of the above. I think WWII German went that way, too, but I have been known to be wrong, on occasion!!!!
      • biggsgolf
        • Jan 2020
        • 1036
        Thanks guys, working on a gear box to convert single drive shaft wtc to dual
          • 898
          Either way that can be handled by reversing the motor rotation and switching the props from side to side-a safe bet is that all multi prop subs have left and right rotating props.(although they might be on different sides (of the boat)
            • 14014
